I got mine setup and everything done up to the point of connecting to the ECU, it doesn't connect???
I'm going to try some changes tomorrow and try again.
Guys, zero luck on this. I tried uninstalling and reinstalling three times and when I get up to the point of connecting the laptop to the LC, it says unable to connect to ECU.
Any suggestions?
Any suggestions?
Operating system details? 32 bit or 64 bit OS? Drivers for cable are 32 bit only. 64 bit windows will require running a 32 bit version in a virtual machine...
It is a 64 bit operating system. So I need to find an older laptop to run it on?
If you have an older one lying around that would be easiest. Otherwise if it's Win 7 Pro you can install an "XP Mode" for free.
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Basically downloads and installs XP in a Virtual PC. Then you start up that virtual XP installation and install Techstream within there. One more button click to allow the virtual PC to capture the usb cable and then it should work just fine...
What's a leaking globe?Hi super90,
I'm in the same ballpark '03 with 150k. i think one of the globes is leaking as I can hear the scratchy sound once in a while when it goes up. With your experience with the ahc and the ome, do you think it is worthwhile to change the springs in my situation or just swap to an ome setup?
Appreciate ur comment.
Gary
Thanks mate.
I am still asking myself the question if it will work on mine as you guys can use the Scangauge while I can't on my LX470.
You may need to describe which one that was Tuffcruiser. That eBay item has disappeared with all its information.
I see the AHC as a very handy thing to have if the Vsi 50 laws ever happen in Australia.
What it means is you can only have a TOTAL of 50mm (2 Inch) lift or tyres or body lift above standard.
So if your running 33in tyres you can lift it 1 inch that's it!!
