Hello,
I am new on this forum but I knew it for long time and like multiple threads being discussed over there
I own a 2005 HDJ 100 (vxe - European specs). I really like it.
I actually bought it because on 2011 I took part to the Mongol Rally in a used ambulance. The plan was to drive the ambulance from the south of England to Mongolia.
Unfortunately, the gearbox failed and we had to give up in Kazakhstan (Astana). One guy we met there offered to store it in the backyard of his house and to keep an eye on it. Since then, it is waiting for me (and for a new gearbox...).
This was the reason why I bought my LC100.
I plan to salvage it during summer 2013 so I try to prepare the journey and to service properly the Toyota.
I have bought the 35-dollar diagnostic plug (discussed in many threads of I8mud) to assess the condition of the AHC (amongst other systems).
Thanks to Techstream, it appears that the pressures are as follow:
- From low to N: Front: 7.6MPa-g ; Rear: 6.4MPa-g
- From N to Hi: Front: 10.1MPa-g ; Rear: 7.5MPa-g
Based on the values given by Toyota's specs (6.9MPa [+/- 0.5MPa] for the front suspensions and from 5.6 to 6.7MPa for the rear ones), it seems the pressure from low to N position are almost within the limits but, the pressure when the suspension lift up the car from N to hi position seem much higher the limit.
What would you do?
It seems the accumulators are in good condition (difference in oil level is visible between low and hi position, as per Toyota specs).
Would you mind changing the rear springs and tighten the torsion bar?
Please find hereafter 2 printscreens from Techstream:
From Low position to N:
From N to Hi position:
In addition there is a parameter (RL after height adjustment) which keeps displaying 0 mm, would think a sensor needs to be replaced?
Thank you
tibo123
What would you do?
Thank you
tibo123
