Definitive(hopefully) 80's spring selection thread
I am happy with mine now, but if I ever decide on a higher lift, I still want to maintain some of the driving characteristics I am enjoying currently.
I would respectfully suggest OME Competition springs for you with OME sport shocks. With Slee heavies in the rear and 5" OME comps in the front and both anti-sway bars on, my 80 felt like it was on tracks. If you went with the 3" comp's you could corner like a demon!!
Great inputs!!!!!
The point of the thread is to have a reference point for comparison, we still will keep swapping springs based on our changing needs but at least it's not as much of shot in the dark.
For example if I want just a bit more lift I can go for springs of similar rate and just a bit longer or something heavier also etc....
Springs aren't magical, they are intact quite simple and not giving out information is simply ridiculous!
I like to have a firm ride. Sports car like ride. I don't care about a plush ride, able to absorb bumps. I want it to be able to corner the way I want to, evasive maneuvers should not be a near death experience.
Soooooo, I want some stiff springs. Now, I need to know what the damn compression rate is on those Holy Springs.
Should I go with Slinky? OME? or others?
Yes, the shocks make a huge difference too, I also like them HD.
And, no I don't carry any weight. I took out the 3rd row, took out the spare tire mechanism from under the car, to make up for the added weight I got on my custom made rear bumper with a spare tire holder on it and the ARB up front ?
If you want firm, i wouldnt go slinky. Lift will have a lot of factor as will center of gravity. Do you have a roof rack? Roof top tent? What size lift and tires are you running?
No roof rack of any kind. Nothing on top.
I am currently on OME stock height plus 30mm spacers all around. Bilstein HD shocks. Both sway bars on. 285/75-16. 305/75-16 for off road.
The COG concern makes me think more about adding a 1" body lift and change nothing with the suspension. That extra body lift would allow me to get some White Knuckle sliders which are meant to work with the body lift.
I was also contemplating Dobinson 3" dual rate, but... what exactly am I getting along with that awful color?
If they turn out to be in the range of the OME 861/862 as far as compression rate goes, than the added benefit of long travel would be very nice. Might not do a body lift in that case.
I would like to stay at 3" of lift at the most.
Ordered the Dobi 2” heavy tapered wire springs Thursday, they arrived yesterday. The color is hideous, but they claimed to be equivalent to the slinky coil at $50/pair cheaper than slinkies, without the revolving US vendor issues.
Do you want any measurements off the prior to install? I can’t give you spring rates, but could give you unsprung height and coil count. Could even measure the coil diameter. Need to know within the next couple of hours.
vehicle is a 96, approximately 7100 lbs, slinky heavy weight springs
front axle measurements. left is first two, right is second two. oem fender flare bottom down to hub, then ground up to oem fender flare bottom. final picture to give you an idea of how rig is outfitted
Yep, so scale, measuring tape, press, compress the springs and get the numbers.:meh:
You can buy Dobinson springs on amazon. If that tells you anything.
This tells me that I can buy them on Amazon like thousands of other products.
Are you aware that Dobinson is a huge suspension manufacturer and just happens to make Slee springs and the famed Slinky’s?
