Deep Freeze Issue
Florence, South Carolina
Took Spartacus out to get propane yesterday and noticed that as the engine warmed the heater didn't produce heat. After about a mile, it ran hot. Limped it back home and found that all the engine components, ie, t-stat housing, hoses, block were hot, except for the radiator.
I kept it in the garage last night and used a space heater to bring the garage up to about 70 degrees, thinking the radiator was frozen. Cranked it up again today with the same result, no heat.
Temps here in SC have been around 32-16 for the past 3 days.
Thoughts and diagnosis please.
After thinking on this for a moment longer, the first place I'd check given the symptoms you described would be the thermostat.
If the thermostat is inop - stuck in the closed position, you're likely to see these conditions. It's also cheaper and easier than the water pump.
Yeah I just replaced the t-stat this summer. Hopefully it's not that.
agreed...thermostat
Looks like scrapdaddy hit it. After Spartacus ran hot I replaced the fluid. It didn't take much so I figured I hadn't loss much. After I warmed it up in the garage it took another 2 gallons and a good burping. Now all is well.
Thanks for everyone's input.
