Death wobble
South Australia
I recently just bought an 80 series with a 5” lift and it has got death wobbles, would anyone know what could be causing it?
Poor caster, bad suspension or steering joints, loose bearings, loose knuckles. What have you checked?
I didn’t really know what I’m looking at so was trying to get some ideas, my wheels need realignment and balancing could that be a problem?
Ok. I guess you're looking for suggestions to have mechanics look at. I would start with a knuckle rebuild. They may have knocked something loose by accident. Hard to know though if you didn't do the work. If you are interested in trying the Knuckle rebuild yourself, the below video will help.
Yep I will give that a try, as I want to learn to do most work myself, thanks for your help I will let you all know how it goes
Most land cruiser shops sell a complete front axle rebuild kit. Being that you are in Australia I can't asset on suggestions of where to get a kit.
Granted this may not be your issue but a front axle rebuild is usually one of the first things people do after purchasing a LC. You will be glad you did it regardless. Being that the knuckle is right near the breaks, and you didn't see this issue before the break change, I would start there on ruling things out.
Look for terrain tamer parts if you're going to do a knuckle rebuild. Don Kyatt is the main distributor, but there might be a SA distributor.
Knuckle rebuild is not the first thing I would look at.
Death wobble is most usually down to a caster issue due to a poorly done suspension lift.
Then worn or loose bushes or bolts on the front suspension. Or loose wheel bearings. Or worn tie rod ends
How was the 5"lift done?
Standard radius arms? Or aftermarket?
Wheel alignment is usually a waste of money. Only thing adjustable without replacing parts is toe in/toe out. It can be helpful to take it to a wheel alignment shop and ask them to give you a read out of your caster and camber numbers, it can help identify what is needed to fix your death wobbles
Some photos of your radius arms could help
5" lift is going to be a sh!t magnet with Highway patrol in most parts of Aus
Well it’s lifted 5” but from what I could tell it’s all the stock parts and they’re all on mad angles
So a picture is worth a thousand words.
Pics of the radius arm where they bolt to the front diff housing will help identify if is all stock.
1" of lift changes caster by approx 1.7 degrees per inch.
Standard caster angle should be about positive 2 degrees.
Assuming yours has standard radius arms and no caster correction.
5" lift will put you at about negative 6 degrees caster.
This is the equivalent of pushing a shopping cart with a bent front wheel, but it's a 2.5 tonne shopping cart doing up to 110 km per hour
