Dead "new" battery
Tierra y Libertad
About 2 months ago I replaced the battery as the old one was not keeping a charge after a few days (1 week) of the rig being parked.
Since I now have a DD I don't drive the truck much during the week.
Yesterday I tried turning over the engine and noticed dim interior lights and the new battery was also dead, the truck was parked for 2 weeks without being used this time.
What gives? I don't think I left any lights on....
Bad ground somewhere?... or also my wife just realized too that when she uses her FM transmitty for iPods/etc the lighter is live even without key (Mazada)... so leaving it in new battery would drain.
Take a multimeter on amps range and put it in series with the battery to measure current draw with all doors etc shut. This will let you see how much current is being drawn by all the electronic bits while things are 'off'. You can then pull various fuses to try and identify any higher current source.
Some possibilities would be after market alarm system, after market stereo/amplifier etc. A faulty alternator (faulty/leaky diode, though not sure on an 80 with its internal regulator) can also drain down the battery.
cheers,
george.
Time for Sears Platinum.
No, I got the costco brand. So I understand the situation, I should be able to start the vehicle without any problems, as long as no lights, cig lighter plugs being on, radio power draws well into x no of weeks since last moved?
X=???
cheers,
george.
I second this method
Thats what they taught me to do when I was doing my first year apprenticeship.
Had a similar problem with a celica and after doing this procedure, we narrowed it down to the aftermarket alarm.
cheers,
george.
You may be on to something. The lazy way would be to not engage the aftermarket alarm, and not drive it for 3 weeks, although I don't see that happening.
"put it in series with the battery" How do you do that?
Disconnect the +ve lug from the battery. Hook +ve of meter to +ve of battery. Hook -ve of meter to lug you disconnected. Have meter on 10A range (or whatever the highest current is on you meter) to start with - just in case.
Unless you want to kill your 'new' battery and have to buy a new one, I'd recommend you figure out what is flattening it with a meter, rather than potentially letting it discharge multiple times as you follow the lazy path...
cheers,
george.
You can buy A yellow top,pink top, whatever color top battery and unless you find what's draining it, The battery will die no matter how good it is. On my old truck the little red diode that goes with the alarm was enough to drain the battery.
if it's an optima yellow top throw that POS away. I replaced one for that reason and the new one was dead 2 weeks later. Complete junk.
I went through two of those in my 4Runner in as many months. They were replaced for free both times and the second time the sales guy talked me into a red top and gave me about $60 back. I haven't had any trouble in 2 years with the red top and the 4Runner rarely gets driven. The yellow top was quite a disappointment.
I also thought I had a parasitic drain at the time but what I really had was two crap batteries.
Sorry for the hijack
You had another problem. An LED will not drain an automotive battery... at least it won't drain it for a year or two.
-B-
-B-
Forgot to mention, the truck was parked for many months without being started.
I'm having a very similar problem. My battery drains down after being parked for about a week or so. It's an Optima Yellow Top, so go ahead, flame on! I used a multimeter to read the amperage draw with the keys out, doors shut, and nothing running at all, and got around 35 milliamps of current draw. That's as far as I got (I never went after individual circuits by pulling fuses). I thought this was a reasonable current draw; it's next to nothing.
I have Georges' LED dome lights, and a stock alarm system. I also have an aftermarket stereo; an Alpine with a separate XM tuner, other than that, I don't have any aftermarket electronics on my truck.
Could someone with a healthy truck (one that's not having battery problems) take a reading and post the results? At 35 milliamps, I think the battery should last several months before draining down.
