Dash pad
G'day been trying to remove the dash pad out of my hj47 cruiser with no luck. I have removed all the screws and that holding it to the cab but it just won't come, is there a nick to the nack to removing the thing.
thank you in advance
dash
There appears to be 5 screws across the front of the dash and the end knobs must come off. then it should lift up and out.
see pic
It is much easier to remove the dash pad with the windshield down. The pad is higher then the cowl and with the windshield down the back of the dash is exposed. You will see how thre are tabs that snap lock when the dash is installed. By getting in there with something to push those tabs down starting at one end and working across you can get it off. Just trying to remove the pad with the windshield up will pull the steel frame off the rest of the pad if it was installed correctly. If the pad has been off before and the PO has bent the tabs so they don't lock as tight it might come off without folding the windshield down.
:cheers:
I just took mine off yesterday. I am not saying this is right, but I got under the pad and bent up the tabs with a screw driver so that it would come out. I think that there were five tabs to bend, and once they were bent up and out of the slots, then the pad came right off.
Blake
