Dash pad missing metal post - solution?
Vae Victus
Posting more than I know
Nashville, TN
My passenger side dash pad is missing the center post that is a push to fit into the dash. It pulled out when I removed the pad initially during the teardown. It's kind of an important one since it's right in the middle of the long section and I'm concerned that it will be loose.
I could probably stick a piece of double sided self adhesive foam or Velcro in there but is anyone aware of replacement posts like this being sold? I was thinking to try to epoxy something if I can get it to stick to the rubber (which is doubtful).
That's a tough one. I would (reluctantly) use 3M trim tape (the expensive stuff used to hold emblems on vehicles) and use a moderate amount - not a 12" section, but maybe a 6" strip of the 1/2" wide tape in that area. It will be totally hidden and with care, you can remove the pad in the future.
You can't really re-weld a stud onto that metal piece, because it's embedded in the dash rubber. I don't think any JB-weld-type product will hold, long term. I think with proper cleaning, the tape will stick acceptable to the dash pad and do the job.
The metal AND the stud are gone. The whole thing pulled out from the rubber.
I agree that the 3M trim tape may be the most feasible.
@mattressking and @Bear inthink given how hard the studs hold in the metal clips that it would be a one time use: when you remove it, it will come off again.
This may be ok though because when does one ever need to take the pads off unless it is because of once-every-45 year rebuild.
I think that's what we call a "bonding fastener" unless I'm mistaken.
Its basically a threaded fastener with an oversize head for bonding to composites and mouldings.
You could try your local fibreglass suppliers, or a friendly boat builder if you can't find them on ebay
