Dash light - brake system
Teesside UK
Hi all. My dash light indicating a brake system problem has come on (brakes are rubbish). I've checked the fluid level and it is fine and the switch is good. Why else might this light come on?
It has a separate light for parking brake, so it is not this.
The warning light was off before I bled system to change fluid (and made brakes worse!!)
Thanks
Dave
did you just bleed them at the brakes? If your Master got too low during this process, you would need to bleed that as well.
Thanks
Dave
There is only one light, it is tripped by two sensors, the parking brake and/or the fluid reservoir level sensor. Either you are low on fluid, the parking brake is on, or one/both sensors are defective.
My LC has two warning lights, one for the parking brake,and one for the fluid level (it is a RHD UK spec). I just wondered if the one for the fluid was activated by some other parameter, I read somewhere that pressures are monitored? If not then it must be a problem with the level sensor.
Dave
Bled at brakes only, just to replace fluid. I have not yet bled LSPV as couldn't free bleed nipple. Tomorrow I will free this and bleed the whole lot again. The level never fell below the m/c ports. With the engine off the pedal is not bad, but with the engine on it goes almost to the floor and will not lock the wheels at 20mph.
Dave
What does the other warning light look like? Figure shape or wording?
the brake light has an exclamation mark in a circle.
never seen that,
in the US we has red light that simply says BRAKE
what does the owners manual say about this ( ! ) light ?
The manual says if it comes on and the fluid level is ok, go to Toyota!!
I guess since the level is OK then it has to be a bad switch.
Find a local shop who has experience with LCs and go to them. Don't get raped at the stealership :)
....I have not yet bled LSPV as couldn't free bleed nipple. Tomorrow I will free this and bleed the whole lot again. Dave
Where is the LSPV bleed nipple? Does a 1990 HDJ81 have this as well? When I had my LC's brake systems serviced last year (pistons, brake pads, etc), the mechanic just bled the brakes at the 4 wheels. Maybe that's because he is just a general mechanic and does not have much LC experience. I don't have the FSM as well.
I might be bleeding my brake system again this weekend as I have sprung a leak in one of my fittings. Appreciatie if somebody can show me where the LSPV fitting is (pic or scanned FSM image), that would be very great - I'll have my mechanic include the LSPV in the bleeding.
