Dangerous Issue -Traction Control Light & Buzzard
Burbank, CA
First not sure if it matters but I installed 33" BFG's (was 31") & cleaned my engine just before this issue was detected.
On canyon roads while taking sharp right turns ( although it happened a couple of times going left) the Traction Control will engage (buzzard) sounds & the ABS will engage pulling me over into on coming traffic.
- Does not happen all the time (i.e. when I tried repeatedly to make it happen again by going faster nothing happens)
- And when I'm not trying thinking it's fixed it will happen.
- Seems to happen going downhill into a right hand turn mostly.
- Some times I'm transitioning from skinny pedal to brake, sometimes when I'm lightly on the brake
- All occurrences on Dry pavement
- I cleaned the Front Right & Left Wheel Sensors
- I have checked the wires on the front Wheel Sensors all seems good.
- I have checked for Codes -Nothing
- I have monitored Wheel Speed while going straight & all read the same speed.
I'm not mechanical but is there something I can do before I take it in.
BTW here is a link to similar complaints Lexus LX470 Electronic Stability Control Problems -But I can't find there solutions.
Thanks in advance.
Is your truck lifted at all? Still using AHC?
I haven't experienced this in my LX, but did in my '00 LC. I believe it was due to the front end being cranked up too high, but never got a chance to find out before she was taken out by a dump truck.
No Lift yet, still have AHC.
It's pretty level up front maybe off 1/4 in
The common culprit creating this problem is worn steering rack bushings or the steering rack itself.
Check the rear speed sensors also. If they look ok try a zero point recalibration.
I had the EXACT same thing happen last weekend, Still trying to figure it out. Happened three times on Monday and not again since. Techstream shows all the sensors reading normally. Did a zero point calibration anyway. Going to get it up on the alignment rack on Tuesday to check everything out including the steering rack. Please post up if you find the cause.
Wheel speed sensor reads the rotation of the wheel hub here.
1986443
If front end loose, this can confuse the computer into thinking one wheel hub turning at a different speed than others.
Very first place I'd check is wheel bearings. Adding bigger tires, puts added stress on the wheel hub. If bearings aren't very tight, this would allow hub to shift just a tad.
Steering rack or ball joint slop, would add to confusion of wheel speed sensor.
Place jack under one LCA at a time and inspect wheel bearings for looseness and all ball joints along with rack for play.
I also have experienced this and have checked and replaced the stuff mentioned above and still have the issue.
The yaw sensor also plays a part, have seen a post here where that was the issue. Have not got around to replacing it yet.
Happened to me a couple of times after we lifted. Turned down the torsion bars and went away. These trucks need a little bit of rake to drive properly.
We had similar issues on my son's LC prior to cleaning up the play in its front end (rack, rack bushings, TRE, ball joints, etc), even after all of that a "zero point calibration" was required to get it completely cleared up.
Maybe a dumb question, but are your tires properly inflated? I had this issue when I first bought my truck, before I had new tires fitted. The left front was about 12 lbs lower that the right, and it wreaked havoc at highway speeds until they were properly aired up.
Thanks for all the replies.
I'm going to look up how to check out the various parts mentioned, and report back.
Btw tire are inflated to 40psi, per tire shop recommendation.
No change. Thought it went away after a Zero point calibration, but I have experience the same symptom again.
Steering rack bushings does not move at all until you get to the extreme right or left of steering wheel movement.
I've been wanting to sensor lift the truck, but kinda wanted to fix this issue first.
Delete the VSC, put on a switch. There is a write up on Mud.
