dang manifold gasket
Seattle, WA
Ok, so I had to fix my heatriser a couple months ago and in the process put on a new manifold gasket and everything was great. Well my cruiser has been running like crap lately so today I went hunting for a vacuum leak. Well you guessed it, the manifold gasket is leaking in two spots. :mad: I tightened the bolts but it didn't help. So now I guess I have to replace the gasket again. My question now is do you guys have anytips on putting on the gasket? This is the three piece metal one so it is a pain. I put some of that copper permatex on the gasket but it obviously didn't help. The engine is the original F135 if that helps any. Thanks for the help. :)
make sure that the intake and exhaust manifold are not warped.
You running a header?
I typically run two gaskets at the same time..
I did some researches on the lcml list before replacing my gasket, basically I did:
- Removed the whole thing as one unit and don't separte the intake/exhaust manifolds if there no need to
- Used a flat ruler check for the manifold flat mating surface.
- Cleaned up the surfaces, careful not to scratches them.
- Used OEM gasket
- Gasked installed dry with no sealer
- Got two taps and cleaned up all the threads.
- Replaced all the studs/nuts/washers with OEM parts.
- Torqued everything into specs.
- Retorqued the bolts again after 100 miles or so.
No more leaks since. Carefull not to break the studs! Or messed up the threads...
/td
I am not running a header, just the stock intake and exhuast manifolds.
Check to see if they are warped...
It's dang hard to warp and F135 manifold because the engines just run so cool! Usually what has happened is that the spreader clamps have bowed so badly that the manifold bolts bottom out before the clamps get enough pressure.
Are your spreader clamps bowed on the manifold side? They should be flat.
They don't fit perfect on there, I bet they are a little warped. I ordered some new ones with the manifold gasket and also ordered new bolts. How cool is cool. My F runs at about 180-190.
WOW, I didn't notice that last part where you said they should be flat. Mine are bowed, I thought that is how they where supposed to be. :doh: Well, hopefully with all the new hardware will solve this problem.
Ok, well I got the new gasket today and the new bolts and spreaders and installed them with a friend(a who lot easier than by yourself :D ). She started on the first crank and pured like a kitten. Thanks for all the help. :beer:
