Dam vacuum leak...
Chicago
Website
www.engusa.com
Hello,
I have a 1975 with 2F stock and Asian crab.
I have been working on this forever now. I have read a lot on this site with trying to find the source.
The problem starting happening when I would accelerate the car would sputter and not get any power. Sometime it would go away and other times it would never accelerate. It would also backfire on occasion and when I would turn the car off it would rev up and then finally die when the keys were out.
I have replaced, plugs, checked the compression on the engine (all good), replaced fuel filter, rebuilt fuel pump, replaced intake manifold, rebuilt the carb, replaced some vacuum lines, replaced starter with Denso from mid 80'c cruiser, and has a new battery as well.
I followed, I believe it was Treeroot's write up, and when I cover the carb with cardboard it will shut off and does so with out reving up. However I still think I have a vacuum leak because when I try to tune the carb and adjust the idle mix screw it does nothing. On top of this it seem every time I try to start my engine, after a few days sitting, I have to play with the idle speed and idle mixture screw to get it to turn over.
When I put a vacuum gauge on the engine (brake booster to carb) I get different readings depending on the day. I'm in Chicago so if it was new and perfect I think it should sit around 18. Now it will be between 15 - 17 depending on the day. Steady at that reading during that time. I will not jump around.
This weekend when I was trying to tune the crab with the vacuum gauge and tachometer it was reading 15 steady but the idel mixture screw had no effect on the RPM's. Never seems to speed up or slow down the engine when I turn it. The idle speed screw will effect the engine.
When the carb gets to much gas, because I'm pumping the pedal to get it to turn over, I noticed a bit of gas coming out of the primary throttle at the c-clip on the front side of the carb. The primary throttle plate is on a bar and that bar runs through the base of the crab and is held in place with a C-clip. I assume it leaked becuase the carb was flooded from me punching the gas pedal to turn the car over. Is that normal? Should the carb leak like that? If fluid can get out can air get it or is that a one way passage and normal?
Sounds like a timing issue to me for whatever reason. Is there a vacuum advance?
Get the thing idling in a somewhat normal fashion. Do the carb cleaner spray trick all around the manifolds and carb gaskets--any where there are vac lines-see if the engine jumps in rpm.
The engine revving when shut off may be indicative of a bad idle stop soln?
x2 on timing. and you probably have at least a minor vac leak, but i bet its more of a timing/carb tuning issue. use the lean drop method in the FSM
I have taken off the intake mainfold and inspected it. No hole to be found in the base of where the carb attaches or anywhere else.
its not holes you are looking for mainly but its the warping and separation between manifolds and head and degradation of the manifold gasket. or the carb coming loose from the manifold. maybe you are due to have the manifold resurfaced.
How do the points look? Or have you upgraded to electric?
I will try the crab cleaner around the spaces you mentioned. I did get a new idle stop solniod becuase that is what I read should fix it. I'll have to pay more attention if the car will die when I kill it or trys to rev up like it use to.
15 to 17 inches of Hg is not a bad vacuum reading. Am wondering lf your idle speed screw is set too high and your dizzy not advanced enough...
It sounds like a manifold vacuum leak.
I think I might have found a leak between the engine block and manifold. Still need to do some more testing. However I have a few more question as I try to keep educating my self of carbs.
It seems I can only start the engine over when the idle speed screw is turned very far to the right. The engine will fire up and run strong (assuming I can get it to turn over). The vacuum gauge I have hooked up will read ~17 now. But when I lower the idle speed screw down to set the RPM's lower I will lose a lot of vacuum pressure, and it will start to jump. If I turn the idle spreed screw too low the pressure will drop below 10 and will jump as low as 8 and sometimes eventually die. Is this a sign of a vacuum leak? Does higher RPM's set by idle speed screw help mask a vacuum leak? That is why I get good pressure when the idle spreed screw is almost all the way turned right....
Also today when the engine died on it's own becuase I had the idle speed screw too low so the pressure dropped I noticed the carb bowl was now really full and the secondary throttle has a lot of gas in it. I could hear gas dripping into the secondary when the engine was off, this was new to me. When shined a light inside the carb I could see standing gas in the secondary. I did not try to re-start the car with the full bowl and standing gas in the secondary. What should I do, anything?
yes you need to do a lot. you def have a decent vac leak. it would be wise to have the manifolds machined flat again and put on a new fel pro or remflex gasket. your life will be easier if you replace the manifold bolts at this time with new ones or studs. i like the studs because you can hang the manifold on them and put the nuts on with out holding the weight of the hole thing with one hand. are you desmogged? after resurfacing manifolds, split them apart and check the heat riser plate if it is still intact. there are 2 gaskets between the manifolds that should be replaced also. you will prob want to replace the 5 bolts that hold the manifolds together too. so yes, lots to do. good luck. its all very easy.
I did replace the gasket between the engine block and manifold with a new one from SOR. On the ports where I detected the leak I was able to tighten the nuts on the studs further. However I was not able to test again because I had to go and I was not sure with all the gas in the secondary throttle if I should try and turn it over.
I took the intake manifold off once and checked for cracks. I believe the heat riser is the area on the manifold directly below where the carb attaches above, right? If so it had no cracks as I could tell.
Also I have headers. I was told they are hedman and seem to be OK. Do you know anything about carbs and if having gas in secondary is a problem? If I can turn the engine over again and the tightening of the nuts did not do anything I will see if I can get the intake manifold machined down. I assume that is a lot cheaper than buying refurbished one online.
Desmogged? Not sure. It as a CA car. It has a few vacuum lines coming out of the carb. One goes from below the idle mixture screw to the distributor cap. One is from the base of the carb to the secondary diaphragm. The last is from the top of the carb right where the air filter case attaches and it goes to a circle thing on the driver’s side top of the carb. To a circle thing that is attached to the carb by a bracket.
Yes! You have a vacuum leak. The only sure way to cure a leak in that location is by removing the manifold and having it surfaced. You might be able to slow/stop the leak for a short time by tightening the bolts, but it will only be temporary as the problem will return.
(quote)"It seems I can only start the engine over when the idle speed screw is turned very far to the right. The engine will fire up and run strong (assuming I can get it to turn over). The vacuum gauge I have hooked up will read ~17 now. But when I lower the idle speed screw down to set the RPM's lower I will lose a lot of vacuum pressure, and it will start to jump. If I turn the idle spreed screw too low the pressure will drop below 10 and will jump as low as 8 and sometimes eventually die. Is this a sign of a vacuum leak? Does higher RPM's set by idle speed screw help mask a vacuum leak? That is why I get good pressure when the idle spreed screw is almost all the way turned right...."(quote)
This symptom is very common with a large vacuum leak. The air/fuel mix is so lean that more fuel has to be added by way of the idle circuit just to be able to keep the motor running. Then the idle speed/mix is usually messed up so much that the idle speed will be high, and often you won't be able to get the idle speed to go down to normal.
Don
the symptom is also very common for headers. that is a major detail you originally left out. it is very common because the header flange and the intake flange thickness are not the same out of the box. they must be machined to the same thickness, or using half washers/shims to pad the bolt head/nut up to "make" them the same thickness. and you should be using a remflex gasket. they squish a ton and help the most to make up the difference in thickness. but to do it right, you should have the header flange machined to the intake flange's thickness.
Yes, there is a problem with the needle/seat/float that is allowing the bowl to overfill with gas. The gas level is so high that it is dripping from the bowl out the nozzle and piling up on top of the closed secondary butterfly. It is also dripping out the primary nozzle and getting burned in the engine, up until it drowns out the engine. Fix the carb so the float level is always about in the middle of the window, and it may straighten up & idle right.
So my dilemma is do I have a gasket leak on the intake manifold or exhaust header? When I spray carb cleaner around the last intake and exhaust area, closest to the cab, the engine will bog down. Which also makes me wonder why it bogs down because I thought, from reading, the engine should speed up.
Not sure what to replace or get machined. The header seems old as is all rusted but no holes. If I get the intake header machined flat and there still is a leak I guess I will know the header is bad…… thoughts?
Thanks I did some more reading and that helped. The gas level is now lower then half way up the glass but I will correct when I get this vacuum leak fixed. Thanks for the info as its not over filling any longer.
