Hey y'all,
I just completed installing the OME Dakar springs + TPI shackles, frame pins, U bolts and Black Diamond shocks on my '76 FJ40. The ride feels great...tight, smooth and solid and tracks nice and straight down the road with no wander. One weird thing resulted though and that is that my steering wheel is now rotated about 45 degrees clockwise when I am going straight even though it was formerly centered before the new suspension. The only thing I can figure that may have caused this (I did nothing to the steering box or drag length, etc) is that the old front spring on the driver's side had a couple of bent leaves and was about an inch or so flatter than the passenger side. The new Dakars of course were exactly the same. Even with this old bent up front spring, the rig tracked nice and straight down the road, sat pretty level side-to-side, the steering wheel was centered and I had no uneven tire wear in two or three years.
Any ideas on what is going on? Anything I should worry about? Both new front springs have their center pins in the spring perch holes. I realize I can pull the steering wheel off and rotate it a spline or two so that it is centered when the wheels are pointed straight ahead but it's bugging me why it is no longer centered.
Thanks,
Pete
Thanks,
Pete
