Build cuttin up the lx
Any chance you want to sell those bump stop extensions?
here they are. cant remember where i got them. had some for my truck and for my brothers truck before he sold it. cant find them online anywhere now and cant remember what they cost. i want to say they were ~$60
how about
$40 plus shipping for the brand new set
and $25 plus shipping for the used set (has one good bump stop attached, other is missing the rubber part)
let me know if thats fair (or make an offer) and if you want one of the sets.
After looking at it more closely, im betting that is whats left of a lock nut that holds the piston to the rod. I believe the rod is supposed to extend thru the piston but its backed out. When i looked closer, the rod is not fully seated down in the piston. I can thread the rod out but it wont go in any further than it is in the pic, assuming because the threads on the piston are slightly smashed on the end. Anyone ever see the lock nut come off like that?
That makes sense, and no, never seen that. Unless you opened the ram up between purchase and install I'd say there's a problem with the manufacturing of the ram. I'd contact the company you bought it from and ask them!
Got it threaded back through the piston so it was definitely the lock nut that fell off and got crushed in there. Doesnt appear to have damaged anything other than a few dents in the end of the piston and cylinder. No scratches inside the cylinder that i can see. Gonna find a nut for it and throw it back together to see how it does.
This is what it looked like when i pulled it for comparison
Weld?
anyone ever break anything inside one of these transfer cases? i was attempting to climb a 10ish ft high rock at the entrance of a trail yesterday and heard a decent pop when i landed one time. no weird noises on the next 3 attempts and i gave up and took the bypass. wheeled for a couple more hours and then hit the gravel road back to camp. when i got on the road i unlocked the center diff like usual, nothing out of the ordinary until i went around a turn, heard some binding and metal clanging noises and the truck kind of bucked a few times. i can recreate the noise/binding condition by switching from reverse to drive or hitting the throttle, letting off and hitting again but only randomly, doesnt do it every time.
i jacked it up in the garage (all 4 wheels) and the center diff wont fully disengage. the actuator runs but the front and back are still connected most of the time. i can roll the back wheels back and forth and make it disengage from the front for a second but after rolling them a certain amount it catches in the transfer case and starts turning the front again. you can actually feel something clunk and the front starts turning with the rear.
the viscous coupler is removed so normally i can spin the front and rear independently of each other.
any ideas? gonna tear it apart in the next few weeks hopefully and investigate.
Just read through all this and don't know if I missed it; is your front axle moved forward? @wv_lx450
Wow my guess would be the VC but you had that removed so I don;t know. These things are tough. I never heard of anyone breaking one. Will be interesting to see what it is.
Im guessing something in the locking collar or carrier broke and is binding. Id pull the whole case and just drop in a replacement for now
that was my thought also, something in the carrier/diff of the tcase. couldnt remember what all that looked like in there so i wasnt sure what could be broken. i would have already bought a new case to swap but i need to swap my gears over to it so it all has to be disassembled any way. if i run across a tcase thats cheap enough, i might go ahead and grab one just in case.
my garage is full of other peoples projects currently so it will be a while before i get to it. lol.
