Custom Exhaust, Replace 02's
Kennett Square, PA
Website
cruisin4parts.com
I got my exhaust completely redone from manifold to tailpipe at a local pipe bender here in downtown Newburgh. He took the 02's out, but I'm beginning to think I really DO need them and was wondering what is the best way to put them in an exhaust system. I still have them. Is it as easy and drill and hole and JB Weld it?
you can order a weld in fitting such as this one:
Slee Toyota O2 Sensor Bung
Weld on Oxygen Sensor Bung
Part#: SOF1097 - $27.50
Your ECU will be angry with you until you put an O2 sensor on!
How much did this part cost?
The same exhaust guy can cut the pipe and weld in the bungs. I did mine that way w/ toyota 2 studed bungs so I could use the OEM nippondenso sensors from oxygensensors. com. The studded toyota bungs were only 10$ a piece. Your exhaust guy should be able to find them easily. I did mine that way when I replaced the O2 sensors because the studs on mine were fubarred and I did not want to run a die over them/not much room to work. It was an easy and cheap fix.
You could also weld in the threaded bungs and use the universal O2 sensor from bosch which are half the price of the ND sensor.
I'm surprised there is any shop in NY especially one in the southern tier would leave a pollution control device off.
I don't recall the bung used on the 3FE engined 80's but if you go after market for a universal type sensor you'll be able to find ones that can use a standard bung without getting carried away with the special Toyota mount. The shop that replaced the exhaust system should install it for no additional charge, if not go elsewhere and report them to the folks in Albany. I won't normally object to removing pollution control devices if you live in a state w/o emissions testing or inspections if you do the work yourself and take ownership of your modification but to have a state licensed shop disregard NYS law must have repercussions. Enough ranting, my apologies.
Get one installed before you have your next yearly inspection or it may get costly.
The exhaust redone was $550. Really cheap in my opinion.
Ok, I'll stop by some time this week and tell him to put them in, I'll try to persuade him to do it for free since it is nys law, or just cheap.
You think I should buy the Slee bungs and then go to him or just let the guy find his parts and pay whatever he gives me?
Well, it IS Newburgh...
And my inspection is due this May!
Why would you expect him to do the work for free? That seems unreasonable to me.
Karl
Karl
If the OP asked him to leave off the sensors I would agree that it seems unreasonable. However, if he just asked to have the exhaust rebuilt, and the mechanic left off a legally required component, It seems perfectly reasonable.
bhmMAPPING,
That was my point; however, your post is far better worded than mine.
kARL
Red Beard;
Did you keep your cats or go with something different/none?
Any pics of how you routed the new exhaust?
Red Beard;
Miescha,
Personally, I didn't choose the route of the exhaust, but he understood that I wanted it out of the way, so he rerouted it along the same old path and just welded it real high up onto the mounts. I'll snap a couple photos soon. No cats at all and some muffler he had there... It sounds like a real truck now..
IBCRUSN,
So you know what I'm talking about...:hhmm:
Also, I'm getting my inspection tomorrow, no big deal. Pre-OBD II:flipoff2:
