That's from a possible mixing of red and green coolant. That's EXACTLY what mine looked like when I got it.
It was a brown sludge inside everything.
Unfortunately, my radiator exploded (due to sudden stoppage of a water pump due to bad belts) and the radiator cap was gunked up like yours and could NOT relieve. Split the entire top lengthwise.
I flushed with a garden hose for 20-30 minutes in and out of every hose and orifice that water was supposed to be. I forward flushed, backward flushed, then just let it run until it was clear.
I installed a new OEM radiator (because I had to), and since I was there, I did ALL new hoses (Don't forget the rear heater lines and the PHH) so you don;t have to do a full drain again later.
Make sure you drain the block plug also (accessible from the LF fender with (4) 6" extensions and a deep well hex socket I used 3/8" drive)
After you get it all open and parts changed, fill it with DISTILLED water and drive it for a day, then drain and do it again. I did this part 6 times and it still had a FAINT tinge of brown to it. So, I used about 24 gallons of distilled water total.
When that was enough, I drained it all down, including the block plug, then poured in one gallon of unmixed coolant (I used red because that was all the rage.) Use green now because it is CDan approved and it is a WHOLE lot more available and less expensive.
Then pour in one gallon of distilled water.
Then mix the remaining gallons in your empty container to 50/50 mix and start pouring in until full. Make sure the front end is pointed uphill (like on ramps or higher).
Don't forget to rinse out (wash) the coolant overflow bottle. Fill it to the correct full-cold line.
Start the truck and let it idle with the cap off and continue to fill it until is starts to warm up and overflow the radiator. Install the cap and drive it.
Park it back on the ramps to let it sit overnight and cool.
Check the coolant level in the morning for both the radiator AND the overflow bottle, topping off both with 50/50 mix. It may take 3-4 day (times) of doing this to get all the air out of the system. This is called "burping" the system.
You'll need about 4 gallons of unmixed coolant and the distilled water was in the amount listed in the middle (24 gal)
as you marvel at how s***ty the coolant looks. Take your time and drink slow. It took maybe 30 mins to get the water to clear.
Do NOT break off one of the bolts holding the heat shield on over the exhaust manifold ... this may or may not have happened. Having the shield off helped a lot with seating the thermo. Put in fresh green 50/50 mix.
