cruiser noob
Andale, KS
Hey all,
A year ago I purchased my '97 FZJ 80 from a good friend.
I must say I'm very happy and quite impressed with the vehicle, and it is my first Toyota.
I especially admire the relative simplcity of the drivetrain/suspension design and is reasonably easy to wrench on.
I recently performed a complete front axle service, which was much easier than anticipated. Also while there I replaced all the brake rotors and pads, as the rotors were .050 out of spec.
I purchased everything I needed from Slee, all for a decent price including some swanky cross drilled rotors(hey, they were a few bucks cheaper than stockers). It took a couple of weeks to get the time to do the work and in the meantime the BRAKE warning light came on, I assumed once the under sized rotors and pads were replaced the warning condition would dissappear, but it has not. everything was adjusted and checked per my FSM and is performing perfectly.
Any thoughts?
Master cylinder? Brake fluid level. Old american cars used to light the brake lamp on low fluid or bad master cylinder. G/L
maybe you've accidently dislodged the ABS sensor plug and it doesnt have a propper contact ?
Wouldn't the ABS Sensor light come on then?
Please confirm it is the Brake and not ABS light
If Brake light, wouldn't that indicate emergency brake? what else feeds into this light?
BRAKE = fluid level or sensor at the hand lever.
We just did this yesterday (and quite a few times before that...)
https://forum.ih8mud.com/showthread.php?t=178210
By far the most likely causes are low brake fluid, thereby tripping the sensor in the master cylinder cap, or a bad sensor (in the cap) itself. E-brake sensor/switch might be next on the list.
Look in the linked thread and you'll see how easy it is to check the MC cap sensor.
Curtis
ABS system works fine , and if it were that it would be lighting up ABS.
This is the same BRAKE that indicates the parking brake is engaged or probably low fluid level, fluid level is fine, but sensor maybe crapped out.
I set up parking brake with the new rotor/drums per my FSM.
The BRAKE indicator is lit and gets brighter when parking brake is engaged, I have'nt checked into switch adjustment (if any) yet.
P.S.
I'll do the cap test, thats probably it.
Thanks much for the link.
