Sorry the reunion has been postponed Brent.
John didn't want to give it back w/o figuring out the misfire.
Wasn't the misfire the deal that started this whole saga?
I have a 94 ECU for a spare. Let me know if you need it.
Damn dude, all this money you could of had a rebuilt motor with all new electronics by now! Sheesh!
Has anyone checked the downpipe behind the EGR? In many cases this is where a short occurs do to melting harness.
I have a spare ECU too Brent. It's one that will leave you stranded (the bad version Toyota made) but it will at least let you know if the misfire goes away. You're more than welcome to borrow it. I carry it as a spare.
Changing the ECU is about a 10 minute job. Extremely easy.
you never said what the fuel pressure was like... pulling the pump is quick as there is a access door in the floor....
good luck...fuel or ignition...sounds simple uhhh....can be a pain in the @#$%
btw.. double check and clean the grounds...on the motor and body even a loose one will cause weird stuff...watched a good freind who is a great wrench work on a car for 2 days for it to be a loose ground hidden on the back of the block..it missfired when cold, (brand new gm car)...
