Before anyone flames me for using cruise on my 80....I don't NEED to use it...just bothers me that it doesn't work.
On my '97 it just won't work. When I click cruise the light will stay on for about 3 seconds and cut off. The first fix (about 6 months ago) was to wiggle the throttle cable and then it would work the next time I would drive. Now it won't engage no matter what. Hit Cruise and light illuminates then clicks off.
So I took the cruise module out of my '94 (cruise works on it) and I put it in the '97. Then when I hit the cruise button the Cruise light stays on forever (until I hit cancel) but the cruise control still does not engage. I checked the fuse.....not sure what else it would be. I ended up putting everything back in appropriate Cruiser. The parts are the same.
Thanks for any help!
, I had problems with mine, the flashing light, I don't know what I did, it worked again, I think it was the abs was getting a mixed signal, and this will do it. You guy's are missing the harmony of a long drive with the sound of a purring Cummins
I recently purchased a complete CC system to see if I can correct the 5% issue.
