Creeper U Joint
North Front Range, CO
Anyone try using the Creeper U Joint on an 80?
Creeper Joint™ Drive Shaft U-Joints
Trail-Gear now offers the strongest U-Joint on the market. We took the stock U-joint and kicked it up a notch by adding additional material to center of the joint. The Creeper Joint™ has been tested to 4,700 ft-lbs of torque in our axle testing machine. These U-joints fit most 1979-1995 4wd applications. Includes four install clips and Zerk grease fitting (not shown in photo).
Are they for daily use or off road only?
Looks like it might be a pain to replace them with no room to wiggle them back and forth in the housing.
I'd be more worried about breaking the yoke part of the joint if the spider is now reinforced... a spider can be replaced; the yoke not so much
How many factory joints have broken? I have seen them worn out, mostly from lack of care. Don't recall ever seeing one that is otherwise in good condition, catastrophically fail?
Not looking for a lifetime u joint, as I just posted in new post, I need a cheap short term good u joint.
I think you are missing my point. If you need a new joint it's likely due to poor maintenance. A cheap joint will likely fair much worse given your lack of attention. And how cheap do you need? The OEM stuff isn't all that expensive.
I replaced all the u joints at about 210,000 mi. The rear rear u joint failed at 438,000 so that's about 225,000 mi on it.
When I had a home, I greased them all the time. The years i was on the road, they never got greased, 2 to 3 years of no or very little grease so yes, they are neglected.
I changed the oil either in the parking lot at the employee housing, used a trash basket to change the oil. I also bought oil and had a Toyota dealer change the oil. Didn't drive too many miles during those times but I did do a several cross county trips looking for work. If I made it to my storage unit, I would grease everything but that was few and far between.
I had no idea I would be still driving this 80 with 439,950 mi on it. I thought it would be worn out or too costly to drive do to price of gas. Both thoughts were wrong. Right now its front wheel drive. Got 15 mpg last tank. The well worn Newfield wasn't clicking, wish it would break so I could warranty it out. The Newfield has about 200,000 mi on it.
I gotta know. What's a Newfield? Maybe spell check messing up Birfield?
Landtoy80: FWIW I use the Valvoline Palladium grease (3% Moly) on my U-joints, figure when the grease gets slung out some Moly will stay behind for some protection. I've noticed over the years that the grease does get slung out of the joints quicker than it used to. When I recently greased my rear U-joints after about 10,000 miles (usually try to grease them every 5-7K) I found them totally empty; pretty much zero old grease came out. I figure that the seals on each end cap just don't seal as well as when they were new. Now at 343,000 miles.
If money is really tight (been there), something like an Autozone Duralast U-joint with a Lifetime Warranty is one option; just keep the receipt for when they go bad to get a free replacement. As already mentioned above, if the OEM U-joints are kept greased they last about forever, IME.
