Crazy Vibrations
Sacramento, CA
I was driving home from some good old 4 am wheeling when I first noticed a vibration, but it was only in fourth at top end. Then, the next day, and since then (that was Sat/Sun), the vibration has been getting worse and worse. The truck is fine through second and third (dont use first, too low, not worth it :) ) but when I shift into fourth it starts this crazy vibration, like something isn't balanced. It will also do it if I stop accelerating in third, and try to keep it at a certain speed. I think that this problem may be an unbalanced rear driveshaft, or maybe it might not be tightened down enough or straight, but I wanted your guys' opinion before I start wrenching. Thanks for the help
If it's not a vibration comin at ya from the steering wheel, then the driveshaft is THE place to start.
Check them sooner than later. I had a similar problem on my '81 truck several years ago. Dropping a drive shaft on the highway is an experience you'd like to avoid if possible.
-Matt
yeap, well, got some time to look underneath at the DS and what do I find? only two bolts. That's right, TWO BOLTS. :mad: :censor: The guys who I took it to to put in the new tranny and T Case decided to only put two bolts back on to connect the DS and the diff's out put shaft. So, off hand, does any body have the sizes of those bad boys, or will I have to go and spend an hour at the local freaking handy shop to try and find them? also, any poundage, or just as tight as possible?
I have had problems with that it seems the only way I could keep those bolts in was loctight I did them up to torque a few times and even retorqued them after 100KM but they still came out. I strongly suggest loctight.
Cheers
Get some Toyota from Cdan (see vendor section) or local dealer. I wouldn't trust anything else unless you really know your hardware.
It is very possible the shop installed all four and two loosened up and fell out...
Everytime we reinstall a d-shaft at the LC shop I work at, blue loctite goes on the bolts.
chuglife said:
you should be able to tell just by looking at it if it's not tight enough or straight, but it's common that the bolts come out of your driveshaft flanges. always put loctite on those bolts
like i said, it's common for those to fall out, probably not your tranny shops fault.
