No rock climbing here in Houston but kinda curious as to what's the most effective ratio for the 80s?
How low can you go?
Imagine a combo of portals, crawl box and 529s
I'd like to see gears lower than 5.29s, or a cheaper crawl box; but it looks like I'm gonna have to go portals for that.
I have a 76 FJ40 but I'm at 198:1.
I have the stock 2F, stock 4speed, AA Rock Box and a 3:1 Orion. I have 4:11 in the diffs. I would not go lower. Wierd things break with a tap on the skinny pedal.
Like TiredIrons 80?![]()
Yup, and I think I will be there in the next 2 years![]()
You don't need those kind of crawl ratios for a large displacement engine, auto tranny rig like an 80. For the kind of wheeling the 80 is suited to do to its large size, a low range reduction (crawler) and 5.29's is all you'd ever need, and even that is overkill if you care about body damage.
You try to get much more extreme than that and the weird things breaking will be stuff like your windshield when you roll it.
I believe any 80 used for rock crawling can do with a lower ratio than just 5.29's. Nay, I should take you out in the ShortBus. Having crawler gears is so much nicer than having to modulate crawling with the brake while keeping the engine spooled up.
A doubler or a crawler box is ideal since you do not loose your low range, you are just adding low-low. 2nd to that would be a 4:1 ratio in the transfercase. That should work for most people with 35"+ tires.
Its the single best option that I did to my FJ62. I used a Klune and the slow control is awesome. My 45 has a Marks box, and although I am not familiar with wheeling 80s without one, I am pretty sure they would be better with. There are some options coming in the near future for 80 owners. We will post up when they become available.
G
I disagree. I think that an 80 needs more reduction to help stay in control of the vehicle to keep the windshield from breaking. And I'm not talking crazy numbers. But engine braking could be better maximized if there was a lower gearset available.
I was putting arround at a construction site the other day, it did not seam that there was any engine braking at all at idle wile in low on my A343, stall range of the converter? seams like doing a manual switched torque converter lock would more effective than gearing for compression braking. maybe tie it to the brake switch so it kicks out when you tap the brakes so you can stop without stalling. then reengage it after you get going again, could be very jarring otherwise.
