Crashing over potholes
Austin Texas
So I recently purchased this:
No Reserve: 1980 Toyota Land Cruiser FJ40
And I drove it back 560 miles yesterday. There are a lot of things I want to address with it, but one of the first is the fact that it "crashes" in the rear end over smaller road bump and potholes. I am at a bit of a loss as to why. The shocks don't seem bad and while the bushings look worn, nothing is bad enough to explain this.
I searched, but couldn't find a common explanation. That said, I have only ever had one vehicle with leaf springs so forgive my ignorance if there is an obvious thing I am missing.
Thanks!
Its hard to explain, almost like its bottoming out.
Have you ever been an over-loaded pickup that hit a speedbump?
Like that.
It just way too much force for such a small bump.
Hmm, I have read about switching to to softer springs. A lot of people also use Monroe shocks from what I have read. Are those softer?
Clearly you've never driven a 40 before... ;) potholes sound pretty violent since there is no insulation in these vehicles and many hard surfaces to transfer the noise. Also, unloaded the back end will make it even sound worse since it is light and bouncy. I do my best to avoid potholes, even though I've upgraded the suspension. Load the rear end with 1,000# and it should smooth it out some... some! :rofl:
I saw that auction, looked like a good score for $8,500. Congrats!
Dam good deal congrats, late model with power steering, for that price is great.. load some weight in it and see if it improves...
The empty rear of a forty is an echo chamber.
A thick floor pad can help.
I had a piece of ply wood resting on the fenders and a four inch thick piece of foam on top of that covering the whole area that deadened the noise pretty good.
Now have a platform between the fenders with a carpet that helps.
Helped a friend put a hard top on his FJ40 and he had it off inside of a week because it was too noisy for him.
--- Well, you would be right about having never driven a 40 before. Always loved them, but never made the jump. And yes, its a pretty good deal. To be clear, this one has its issues (some rust, some bondo, repaired frame) but I am looking for a drivers, not a show car so it works for me.
Regarding the potholes, the noise doesn't bother me too much, but the physical slamming does concern me. If that is considered "normal-ish" I am less worried.
Agreed. The one pic makes it look like boomerang style ones with a potential horrible angle.
-- I'll take pictures in the morning, but they are nearly vertical. Been reading up a bit on this, but its unclear as to exactly what I should do to fix it. Seems like there are mixed opinions.
The obvious problem I see is your rear spring shackle is not splayed rearward (leans forward), this causes the springs to do all the work since the spring shackle can not splay rearward when bottoming the rear suspension. Next possible problem (not shown in any of the photos) is you could either have load leveler shocks on the rear (nasty shocks with a coil spring wrapped around them) which leaves your rear end "double spring loaded", OR you are merely running stiff valved rear shocks (like Monroes or Gabriels) that give no cushioning to the rear suspension (i.e. you have a buck board that bounces the rear end up on every bump you hit). Ideally you want a mushy rear end (since you have no engine or weight back there), many on Mud use Bilsteins since they are ultra velocity sensitive.
where i live we drive around them good luck on your new purchase
I do not know how Pa. is today, but, years ago growing up there the potholes would eat suspensions at an incredible rate. And, the state had a six month period where you had to pay for an inspection to keep driving. To me it seemed like a racket , keep the roads poor , force inspection, and keep the revenue rolling. I actually broke a rear axle in a giant pothole . Missed it because of soft snow hiding it.
Xx92aFR
Here is the shock. It says "Hecho en Venezuela" so identifying it (and its characteristics) may be a challenge.
I do not know how Pa. is today,....
All the other states drive on the right side of the road....we drive on whatever is left of it.
