Rig: 1978 FJ40 2F
For a year now I have been chasing down an engine shut off issue. It's been mentioned quite a bit on these forums and I have done everything conceivable to correct the issue, however, it still persists.
Reading another 4x4 forum a member had the same issue as I, however, he was driving a newer model 89' Jeep. Another member told him to check his crankshaft position sensor and sure enough that was the culprit.
His symptoms were the same as mine. After 30 ish minutes of driving around the engine warms up and then shuts off. We have to pull over and let the engine cool down before it will start back up. Turns out it was his crankshaft position sensor.
What would the equivalent issue be in the 2F since it doesn't have a crankshaft position sensor? Something is shutting down the engine at normal operating temperature. I check for spark and fuel and have both. Only when the engine cools a bit (10 mins) will it start back up. I've literally done 7 different things based on suggestions by members here and the problem still persists which is why I posed this question relative to the crankshaft position sensor of new model engines.
UPDATE: Culprit may have been a malfunctioning electric fuel pump. It would work at times and then when it heated up the theory is it would quit working altogether or only work intermittently. We replaced it with a stock mechanical fuel pump. Will update in a few days.
