- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,211
I have followed Zane's Oil Pump Seal replacement write-up here
https://forum.ih8mud.com/80-series-tech/72514-how-replace-oil-pump-seal-w-pics.html
but in the process I have broke two breaker bars trying to get the crank nut off.
Has anyone encountered trouble getting this off?
The first breaker bar was a 1/2" cheap one from Harbor Freight but the second was a 1/2" Titan from Northern Tool rated at 376 ft. lbs Max Torque, 72 ft lbs more than the nut is supposed to be tightened too. I'm pretty sure that it is at the correct torque setting since a Toyota dealer did the headgasket, timing chain and complete engine seal kit 8,000 miles ago for the previous owner.
BTW- I had the breaker bar strapped to the passenger side frame rail on both attempts. The first cheap bar sheared the 1/2" drive nub clear off right where the socket attaches. The second destroyed the racheting assembly on the breaker bar even though I had it in the locked position.
After I broke both of these I used a chain vise gripe around the crank puley, strapped it to either frame rail really tight and used a 36" long 3/4 inch wrench and could not budge it at all.
What gives? I am at a loss as to how to get this thing off.
Any input would be greatly appreciated.
In the meantime I guess its back to Northern Tool tomorrow to buy the $80 3/4" breaker bar with a max. torque of 1,000 ft. lbs. and a torch to heat the bolt up before my next attempt.
