"Crank-but-no-start"/"loss of throttle" turned into "Barely Even Cranks problem"
Fairly new user (came across the site when I had to replace the barrel ignition rod and found some helpful posts/links) and I am at my wits' end.
My problem seems to have morphed from the "intermittent crank-but-won't-start/loss of throttle" problem into a "car has trouble even cranking at this point". Below is what I'm dealing with - any help appreciated.
History of problem:
  • (2023-11-06): (Likely unrelated but worth mentioning) Filled up with “suspiciously inexpensive” gas.
  • (2023-11-06): Car started pulling out of gas station; no problems
  • (2023-11-06): Next startup, not 20 min later, started fine, kinda “chugged” for a minute below normal RPMs (just sounded off in general) and engine stopped
  • (2023-11-06): Wouldn’t restart —> towed to shop —> shop was able to start with gas pedal floored
  • (2023-11-07): Took car from shop, everything seemed fine. Life is good.
  • (2023-11-11): Driving a few days later, lost the throttle. Pulled to side of road, started up immediately/on first try, continued day.
  • (roughly 2023-11-15): Some days later, car cranked but wouldn’t start at home. Stayed like that for a few days.
  • CEL is on at this point.
  • (2023-11-16): Pulled out/checked EFI and ECU fuse (both looked good), put back in and the car starts no problem.
  • (2023-11-16): Car appears to be idling perfectly at ~1000 rpms, take a little drive around the neighborhood with not problems.
  • (2023-11-16): Turn off car and try to start again. Doesn't start. Try the "pull out and put back in EFI/ECU fuses" move that worked previously and
  • car still doesn't start and hasn't started since.
  • ( 2023-11-30 ): Tried using starter fluid, sounded like it really wanted to turn over but still didn't start.
  • ( 2023-11-30 ): Car now has trouble cranking, much less starting.
The current status of things/what I've checked:
  • with key in On position:
  • Cleaned the throttle body.
  • Checked APPS - looks good.
  • Checked Fuel Pump & Sender Gauge Connector - looks good.
Ive been chasing an interminient loss of throttle for a while. I resolved it with a new fuel pump relay, previous owner installed a knock off 30amp relay
OEM for the win
