cracked hose, 3fe air intake
AND i was wrong, this connection is important, if the little guy gets out of the air intake hose the motor will not run
I assume since this hose penetrate the intake after the MAF the engine get more air than the ECu planed?
ill be happy for clarifications
Yes, if the leak is downstream of the MAF than the engine is getting unmetered and unfiltered air.
The engine will run lean and the risk of sucking a few grains of sand or even part of the hose into the motor is not worth it.
For a trail repair taping the hose would work but it needs to be replaced with a new hose sooner or later.
For a trail repair taping the hose would work but it needs to be replaced with a new hose sooner or i
If I simply seal the intake. (Remove the thin hose completely) am I impacting the engine performance
You do realize that you could have had the parts delivered and installed by now as opposed to dicking around with this nonsense.
With a massive air leak, the flap in the AFM will not stay open and the fuel pump will shut down.
I recommend Partsouq.com because # One there in your part of the world there fast and affordable.
This is not the place to seek advice if you don’t wanna do it right.
If you plane just can’t afford it say so.
The part are available!!
Arrival time of parts is about 6 to 12 weeks.
Cost of shipment and taxes double and triple the price,
Now you know. In addition, I am new to the forum and try to learn from others experience. The question was about the impact if I delete that hose and seal the air intake hole
Have you checked Partsouq.com, There in Dudai shipping shouldn't be that much. I get parts halfway around the world from them in less then a week. Or is it the customs in your country that hold it up. As for the taxes I can't help you 🤷‍♂️
