looks good man i think i have decided on old man emu 2.5 medium and 35 toyos thanks guys
I feel like I'm still at work.
I finally went and fetched the tires, springs, and shocks from yamapro. Then the 30mm spacers came in right on time, so I decided it was time to put 'em all on. Got the front end done with little effort, though doing it for the first time was more work than I'd initially thought. I pulled a hose loose on the ds front (while trying to get the axle low enough to get the shock out) that didn't leak anything, and appeared to push back in without issue. Other than that, and the realization that I'm no longer 20, it was okay.
Now, the back end was a different story. The top nut on both sides was so stuck that I relented and called the tire place I usually use. They carged me $10 to loosen the bracket bolts that the shocks tie into on the rear uppers. They were not able to loosen the shock nuts without breaking them, and so plan is to remove the whole deal, grind off the old shocks if necessary, and install the new.
I was gonna call in reinforcements (I'm looking at you, finewynsFJ40 and southff4), but at the perfect moment my 6 year old daughter managed to screw up my iPhone badly enough that I had to do a restore on it, and lost both numbers. Woe was me.
So, anyone crazy enough to want to wrench for a while some time this week is welcome to come down and lend advice on how the back should be done... since it looks more technical than the fronts. I'm mostly concerned about screwing up a brake line, etc.
