New tires?
Hard to tell from the pic, but is your 45 SOA?Yes. Used new Falkens. Hence getting sucked back into 37’s. They look the best but took the zip out of her. But im a sucker for a good deal![]()
Yes but seems particularly tall compared to others ive had or driven. Would love to be on 2.5” and 33s actually but that project is at least a set of tires away and would benefit from a 5th gear or OD. Plus theres that inherent distaste for paying to lower a truck
A topic for another thread but i should make a full list to see what all i would really need... I think the dakar/ome was 26-800 alone and then add replacement perches and a steering arm plus?
To lower it a bit, you could start with taking some leaves out of the rear pack. For the front, you could do a shackle reversal and french the shackle into the frame. That should bring it down 1.5-2".They are the original 45 springs. Fronts are pretty flat. Back is still the orig 11 leafs I think. The ride isn't actually that bad.
Thanks! Will keep that in mind. Rear 55 is a different length i believe but I will likely pursue lowering first .... though the fronts could use a left right swap.
Since it's a new day
Whatever i do it has to ride better than the OME on the 55. Brutal rough. Needs some leaves pulled and/or more sidewall cushion.
SOA 37s vs 2.5” and 31s.
Do you have a job?. fawker![]()
