Cottonland Hunting/Shooting Thread
Sure feels good light and simple like this but I guess keeping it "stock" defeats the purpose.
Our big gun show is This weekend.
What price point should I be looking for with rounds and magazines?
Gander Mtn has some that are .50 a pop
Mags are $20-35
5.56 or .223? Does it matter?
Are the cheap shells more corrosive? Dirtier? I'm not that guy that wants to strip and clean my rifle every time I shoot it.
@fj40charles
5.56 on the ammo is my preference, especially since it is rated for 5.56. (If your lower had said .223, but not 5.56 then running 5.56 would be a no-no. running .223 in a 5.56 is ok, but the 5.56 round develops more pressure which isn't good for running in a .223) Good Bulk Ammo should run $0.36 - $0.45/rd, cheap stuff down closer to $0.25/rd. Good source : http://www.bulkammo.com/
30-rd pmag's should be $15 or less. standard mags closer to $10 or under. Midway is a good source: http://www.midwayusa.com/product/2319180134/magpul-pmag-m2-moe-magazine-ar-15-223-remington-30-round
As far as good vs. cheap ammo, if the rifle will run it will determine if you can shoot it. Some gubs are more particular about what they will run. May require more cleanings, so that'd be your call.
I know buying local cost a little more, but $35 for a mag seems a bit excessive.
I've never seen one that mounts to a carry handle. An Aimpoint that is.
I'd say that there's a decent chance you'll run out of elevation before you can zero that dpms with that carry handle rear sight. The gas block front will lack the height of an f marked front sight post.
This is on it. It's fine. The holographic sights are what are pimp.
I'm not sure what I need here but I need a place to mount the front of the sling.
I pulled off the front sight so I have this little accessory bar available to mount it
@wngrog , looks good but I bet/know your cheek weld is killer. You need to get a little riser underneath the red-dot to get it closer to natural eye level. It should really make shooting more comfortable.
I wasn't going to say anything, but yeah, TCB is right. Ditch the budget optic for a Strikefire or Primary Arms Micro. I have the PA, and I love it. And yes, you will need a riser. Both are available with budget risers, but I went ahead and bought the Larue riser for mine. $$$ but worth it.
Or you can opt for a real nice optic and get an Aimpoint T1 or EoTech
I bought the LT660HK for my PA Micro, though for a true cowitness, you would be better off with the LT660
