cooling thread again?!
Brunei
hey there guys,
here's the prob..
i've checked and replaced the rubber gasket on my thermostat..
put in a new water sensor.. but my temp gauge only goes up about 1/5th of the gauge when idling. tried grounding the sensor and the gauge goes full.. that means the gauges working properly right?
i read sumwer sumone has to drive at highway speeds to get it to half of the gauge, tried this but still its up by 1/5th..
after driving i shut off the enginge and start it back in about 2 minutes, the gauge goes to half but goes back down in a minute....
i also noticed the t stat can be adjusted.. do i srew it all the way to the bottom or the other way around?
or could it be my fan? how do i check if the fan works properly?
oh yeah, my cruisers totaly stock...
thanks in advance:grinpimp:
im a little confused,
does it overheat?
what kind of fan do you have, if mechanical it probably is turning if your engine is turning.
