Well I've been working on a bunch of cooling things this spring. I finally got to put them to the test at CM09.
This spring I...
At any rate, crawling and idling around Moab, my temperatures stayed much cooler, and more importantly, my AC blew cold the whole time. Well not exactly the whole time. Thursday morning I was running hotter, and the AC started cutting out. I put it off until lunch when I tested the relay. It worked fine. So I decided I would jump the fan leads to make sure it was working. Well, I found one of the fan leads hanging loose
doh
, so with the help of treeroot's dad, I got it back together, and had nice cold temps for the kids to enjoy the rest of the trip.
I actually think that the truck runs cooler with the AC on now as that fan DOES affect not just the AC, but moves enough air to affect the radiator at low to no speed. I installed the 14" pusher fan that brotherrob put on his. I got it for ~$40 with the relay and mounting kit to the door. I couldn't justify the >$200 for the JDM fan that is 4" smaller and moves a helluva lot less air than this fan (rated at ~2,000crfm).
Thanks to all of those who put in the research hours!
P.S. I have the fan setup for the afterrun. It did run for several minutes at a time when I shut it down on the trail, but I thought it was well worth it, and wasn't concerned withi it draining the battery.
This spring I...
- completed the RT temp gauge mod
- rebuild my OEM fan clutch with 10,000cst oil
- replaced fan blade with 3.0 fan blade
- installed a 14" pusher fan wired through the medium pressure switch (Sumotoy's Part IV of ABC's of 80s cooling)
- Cut up my hood and installed large vents (https://forum.ih8mud.com/80-series-tech/278155-pardon-me-while-i-vent-my-hood.html)
, sorry dont venture from the 80's tech much :whoops:
