Ah, so the actual rear interior heater.
Flushing the heater core.
I'm using some Prestone Flush and Clean. Seems pretty mild. I mixed up a batch into the 5 gallon bucket, put in a submersible pump with the inlet toward the top of the water. That will push the water through the core then the return goes into the bottom of the bucket. The solids should settle to the bottom and clean mix should suck in above.
I will let it run for a couple hours this way, then swap the hoses to push the water the other way.
Once that's done, I will flush with fresh water then distilled water to finish.
If you have the return flowing freely into the bucket you shouldn't have a pressure issue. If the core is so plugged up you are seeing pressure building up, it may be best to reduce flow rate or use another method or pull it and take it to a rad shop. I wouldn't use my large industrial pump or anything but a little pond pump like this shouldn't blow out metal seams.This is a great idea, and I saw another Mud post where someone flushed all three "blocks" of the cooling system (heaters, engine, rad) seperately with a submersible pump.
I'd jump into this method if I felt more confident about not putting the cleaning solution through with too much pressure, possibly causing stuff to burst or leak. You said 600 gph @ 12 feet of lift, is there some overall guideline you would use to ensure you purchase a pump that won't blow the pipes to bits ?
What type of fan belt is that?Progress finally. The local parts guy ordered the wrong clamps and a wrong hose...twice...it's a pretty hookie system they use. Get the part number off the IPB, type it into one system, copy and paste into another system, copy and paste into another system...no wonder he screwed up twice.
Fill and burp tomorrow.
I ordered all the hoses and metal Pipes in one kit for the oil cooler off ebay just last week
Main Heater Core/ Front
Red is inlet, Blue outlet. I ran mine through the valve. If I was running a harsher cleaner I probably wouldn't have.
Rear Heater, not a great pic but it's the two hard lines that wrap under the passenger footwell.
Right now I'm running the carb advance port to the secondary diaghragm with the blue VTV. I was playing around with different recurves, springs and weights, and different base timing. I almost had it perfect and on the primary diaghragm but slight pinging under heavy load...long story short and after having the distributor apart about 20 times with many more base timing adjusts and test drives, this config gives me the best acceleration and cruising power. Base timing is right at 12 degrees. I'm starting my resmog soon so all this is moot.Hey @mwebfj60, what's the story with the vacuum hoses you have connected to the distributor vacuum advancer? Just curious.
Just saw this, the ones in the pic are Dayco belts. I just put on an OEM set and the DayCo belts move to the trail set.What type of fan belt is that?
