Cool new fire extinguishers
I've got one. Haven't tried it yet. Single use.
Interesting concept. Seems like a lot of money for a product that isn't UL tested as a fire extinguisher and can't be used in place of a certified device in a regulated environment ie. replacing the required extinguisher on a boat. It is CE and TUV approved but that is for the folks across the pond. There doesn't seem to be anything in the NFPA literature that I could find. caveat emptor
But, it has some interesting capabilities. It's effective with all types of fire - which is an advantage. It doesn't damage wiring or other parts in the car. Here's a video.
One of a number of Halon replacements ? Don't you love not knowing what you're buying ? Ed
Still not UL tested? It’s been around a long time, I’m going to assume it never will
From their web site, they say it's "Potassium Nitrate based". Potassium Nitrate is a strong oxidizing agent (for example used in black powder), so from my college chemistry I'm assuming they use the Potassium Nitrate to oxidize some solid compound to produce Potassium Carbonate, which would absorb heat from the fire and interfere with combustion.
But yeah, they could be a bit more above board on what the product is. Surely they must have a patent on it.
Cool idea but from my viewpoint it seems like an issue here would be how much "throw" the fire fighting gas has. Does not seem to eject it really far enough, especially if you can only get so close to fire that is hot. I guess it would work great though for smaller fires?
I would imagine you'd have a hard time containing a fire that's too hot to get close to with any extinguisher you'd carry daily. The extinguishers marketed as car size only have a duration of a few seconds; not enough to contain any serious fire.
Next time you have a cheap, non-refillable extinguisher that has dropped below the green zone and into the red, go spray it out somewhere. There's a lot more than a 'few seconds' of time, unless you get those weenie extinguishers that are the size of a 12 oz. aerosol paint can. The small cheap household ones can put out a tremendous amount of fire. I tried to 'drain' one on my property and was getting bored while it was shooting out the dry powder.
I was told during a marine patrol inspection on my boat to annually invert and smack the bottom of the cylinder with a rubber mallet to loosen the dry power which can sorta cake up in the bottom. Ed
TUV, UL, ETL, CE and others are all certification companies. This company just went with TUV instead of UL. Both certifiation companies are legit and will test for the same thing. I have delt with both TUV and UL and it is apples to apples. ETL is European. Having a TUV certification would mean that it has been rigorously tested, documented, and certified for use. I would be fine with buying this product because of this certification. The functionality is something different. I'm still on the fence with the functionality and how it would work.
thanks for that information. Had no idea.
