I have an interruption in the power between the battery and the ecu, I have a work around provided some time ago from tools( kevin RIP) but aneed to find the problem, see below
‘Ok, I have the ewd, and it shows a straight wiring with one splice between the battery and the efi regulator, and then a wire which travels over the head to the harness to power the ecu, somewhere in there I have a problem. So I have power at the battery ( obvious) of 12 plus v, I have checked the fusible links and they are good, a full 12 v plus. But when I probe at the efi re is 0, it appears that there is one splice between the battery and the efi but so far I have not been able to dig deep enough to find it.
also a question. Adjacent to the power cable that the fusible links attach to there is an orphan eyelet that is not attached to anything , is this supposed to be attached to anything? What was it for? To the best of my knowledge it has never been attached to anything. Any thoughts appreciated’
