Electrical confusion
I’m back! With my recurr8ng electrical woes, 97 lx450. Roughly a year ago my truck cut out, with the help of Kevin (RIP) I tracked that problem down to the grey plug powering the ecu near the head, hardwired that and no problems for a year. Two days ago same. Problem reoccurs so I redid one of the connections and good for two days, then again the ecu dropped out. Using Kevin’s ‘limp home’ fix of hot wiring from the battery to the b+ port on the diagnostic plu the truck runs, then last night I lost the headlights, radio, power to the heater blower motor, I’ve check3d fuses under the hood and all look good. It’s snowing hard here so crawling around the truck is a bit of a challenge. The two issues may not be related, any though5s or insights?
cheers peter
Can you provide info on what does work. Engine runs with the hotwire? What else works?
Engine runs with hot wire, tach, speedo, and instruments work, rear dome light works, I think the bulb is out in the over head one,, ‘map’ reader light works, wipers work, rear blower on rear heater works. One thing I forgot to mention is that the transmission will not shift out of park, even with engine running unless I remove the access cap and release the manual lock on the tranny
In addition, all door controls work, windows, door locks etc. The back light for the dash does not work, but the instruments do, I also have a scan gauge and it worked with the ‘hotwire’ but now is blank
Ok My process is different from many but i would mark all the fuses in the fuse box which are controlling systems that are working fine. then I would look to see if there is a bundle that tends to be more problematic than the rest and see which harness those wires go to. I would start under the hood since you already seem to have had issues there. the FSM for all the electrical stuff has some diagrams that help me see how things are grouped as well. No one enjoys chasing these issues but you having a group of things out might help you in this case.
I have two theories at the moment, I’m going to check grounds etc under the kick panel and the adjacent connections and wires.
when I did my ree years ago I re wrapped the harness near the egr pipe, and as far as I can tell it is not burned thru , any ought son this being in that area? I’m going to redo the at I respliced a few days ago and see if that resolves the ecu power issue as I think these are separate at the moment, unless it’s all tied to the main harness and a fault there
it won't hurt going that way. since a lot isn't working if you can identify the main areas those wires go through, you will likely trace it back. I have not had the issue with the EGR pipe area of the harness yet, but LOTS here have and they had all kinds of interesting issues. It just isn't the easiest to get to, so i wouldn't have gone after it early unless it was obvious there is a problem. realize I daily mine but have a backup so i am lazy :)
Look up threads related to the wire harness by the glove box. I don;t specifically recall the issues, but that's a possibility.
I did historically have an issue at that spot, the harness rubes against a sharp metal bracket shortly after it plugs into the ecu, I did wrap it and zip tied it away from the bracket and do intend to check that spot again
