I am trying to do my first compression test and something seems wrong. I warmed up the cruiser pulled all the plugs and disconnected the coil. I borrowed a guage from a friend which he has used quite a bit. I floored the gas and cranked the engine and got the following numbers.
cyl 1. 65psi
cyl 2. 50psi
cyl 3. 65psi
My book says I should be getting above 120 psi. The guage held the number for well over 5 mins why I was looking around so I think it is making a good seal. I stopped cause I don't think my engine would run at these numbers. These guages seem pretty simple and it is hard to belive it would be off so much.
Any ideas?
cyl 1. 65psi
cyl 2. 50psi
cyl 3. 65psi
Any ideas?
