How much oil did you put in? I have found that more than a couple of ccs will raise the apparent compression because it reduces the volume of the compressed cylinder significantly.
IDave said:How much oil did you put in? I have found that more than a couple of ccs will raise the apparent compression because it reduces the volume of the compressed cylinder significantly.
Civil1 said:Nocal:
What kind of gauge are you using? Press in and hold type or screw in.
Those are some low readings, I read somewhere that readings under 120psi need to be looked into. But overall I think that consistency between the cylinders is most important.
I have never changed the head gasket on a 2F, I have changed it on my fuel injected 22R. It looks to me like the 2F could be easier. Alot less stuff in the way. I would start the head gasket and see what that does to your compression.
My vacuum pulls the same 19 in. my gauge is tied into the break booster hose which goes into the intake manifold closet to the number 6 cyl.
Where do you take your vacuum reading from?
65swb45 said:Compression isn't great, but if you're getting 19" of steady vacuum, you should be able to tune a good carb to pass smog. I think you've got a decent shot at it without putting work into the motor for now. You'll want to make sure the VTV on the thermostat are working. Otherwise, timing will lag, and the hi speed test will show high CO from retarded timing. Good luck
IDave said:It seems incongruous to me that you can have that low of compression and still get 19 inches of vacuum.
IDave said:I rather think that you have worn and/or carboned up valves (and worn rings, probably) in all but #6, rather than a headgasket issue. If you had 2 or more adjacent cylinders that were equal and very low I would be thinking more about that. If you have oil in the coolant and/or coolant in the oil, start thinking about the head gasket.
Can the vacuum be different in different areas of a connected closed system like a manifold? Intuition tells me that it is physically unlikely.
IDave said:Just gut instinct. If your valves are worn I'll bet your rings are, too. You do, after all, get some improvement with the addition of oil in several of the cylinders. I would start with having the head done, and replace the headgasket when you do it, of course. Then see what I had. Might be livable.
