Compression increase after milling head?
Had my head milled. Tech didn't know how much. In general what compression increase can I expect from a "mild" milling?
Put some pics up on "My Build" thread which shows the cams, HG et al. The HG was last done in 1998. Thanks
https://forum.ih8mud.com/threads/my-build.516583/
I've read .010=.1 compression points from reading online. I suppose it depends on many factors including combustion area?
I have all the numbers at home, but from what I remember with the compression height, stock HG thickness, and combustion chamber size, that is a pretty close approximation.
Thanks. I appreciate the input.will my butt dyno feel that? I also just upgraded to the blue hub fan clutch for190 bux and contemplatingethamol injection. I dropped by Snow Performance in Woodland Park yesterday and picked their brains. Also IAT sensor coming soon.
Snow Performance recommended pre charger injection linked to MAF/MAP versus based on psi. Any thoughts?
You need to cc the chambers, measures deck heights and so on.
It's not so cut n dry.
What type of machinist cuts anything and doesn't know his measurements.
I'll know in a day or two as I'll call the guy at the shop directly. Stock gasket going back on. Makes sense on the cam timing. I'm including a pic of HG weakness. I wonder how much longer it had.
You will probably feel a gain but it will most likely be from everything being fresh and with no carbon build up on the parts vs. the head mating surface being milled a little to clean it up. Now if it was milled a lot there are performance gains to be had but then depending on the engine you may have to deal with piston to valve clearance and some engines require special cam gears to get the cam timing correct. I've never rebuilt a 1FZ so I don't know if that is stuff you have to worry about.
Definitely do the maf system, your response will be quicker. Post up your results, I'm doing the same set up. Also check out the install @murf did, nice blueprint
