Hi all,
My 1997 FJ80 at highway speed going up hill had total loss of power. No acceleration!
Made it top of hill and coasted down off the highway luckily unto exit ramp.
Engine idled rough - smoke billowing not from exhaust due to oil discharge up from dip stick tube onto hot engine.
No metallic sounds.
Opened oil filler - compression coming out of oil filler assumed blown head gasket as still had power to crawl the road to service station 3 miles away. Bought oil - lots of it.
Then crawled home 90 miles ...took 4.5 hours. While driving home made filler tube out of cardboard so I could put oil in while allowing compression to escape around tube. Used 5 gallons of oil in 6 stops.
Never did temperature red-line. and made sure oil pressure never fell below 15lbs.
I believe their is not piston damage due to lack of metallic sounds. There is no metal in the oil pan - dropped magnet on line down filler tube. I will take the oil pan off to confirm.
oh yeah and I was hauling a trailer weighing about 1800lbs.
Am I crazy to be this hopeful it's just the head gasket. Or should I be anticipating a full engine rebuild?
thanks for your input.
Sarah
No metallic sounds.
Sarah
