- Thread starter
- #381
PitA to mount that rotor to the back of the flange if you still have the factory dust shields on the back.What was the issue Steve? The caliper not hold the driveline? I haven't looked into them in a LOONNNGGG time, but curious what the method of failure was in your cases.
When adjusted to hold tightly when set, it would drag a little when off which caused fast wear of the pads.
Pads were not as cheap as you'd think and weren't available without buying a whole assembly; it wasn't just the pads.
If you're not solidly locked in the axles and you park really flexed out, the rig can still roll due to differential "give".
The rotor was in the way of lifting the driveline when trying to do a simple 1-2" driveline tuck.
In some cases the bracketry isn't protected and gets bent up from traversing obstacles.
