Clutch Questions?
Well I was fourwheeling yesterday and I think I smoked my clutch. What would be a good clutch for fourwheeling? Where is the best place/PRICE to order clutches from for our FJ40's? What is the spline count on the input shaft of the trans. in a 76 FJ40? Also, what is the diameter of the disc in a 76 FJ40? Any help would be appreciated. Thanks.
Brenton
Call Summit Racing or Jegs and get the best price on a centerforce clutch kit and the centerforce throwout bearing.
Stock
Mace said:
Don't feel the Centerforce is an improvement? Is it worse, Mace?
Anyone heard about or used one of those GripForce clutches? Are they any good? Thanks.
Brenton
I have not ever been pleased with a centerforce to tell you the truth..
I guess I should elaborate a bit more.
1. A stock clutch can handle more HP than most 2F's can produce. I can spin mine but it is old/tired/ and is a mongrel. I will probably be looking for a better friction plate for the next clutch.
2. You smoked you clutch most likely because you are not gearled low enough. A centerforce will not really help you here. they are designed to clamp softer at lower RPM's and get tighter at higher RPM's. Not the standard issue for a 40..
I guess my questions are,
How old is the clutch, did it just wear out, is the rear main or the front input on the tcase leaking mutch?
I have been pleased with LUK clutches, and stock ones seem to work well also. There is a heavy-duty option that applies more clamping force. Like Mace said Centerforce clutches rely on RPM for clamping force, not good in a crawling application.
Luk makes an awesome clutch..
I'll stick with my Dual Friction Centerforce Clutch kit, thank you. The throwout bearing is made by Koyo of Japan. The factory clutch can not start to compare to the capabilities of the Dual Friction Centerforce Clutch in my opinion. And I quote Centerforce "While it is true that the centrifugal weight systems efficiency is a direct function of engine RPM, the patented Centerforce weight system is effective and will provide additional clutch performance at all engine RPM levels."
And you have tweaked a toyota clutch past it's gripping power?
I had it happen on a factory rebuild I put in after the original lasted 115K and a lot of wheeling. The factory rebuild lasted 35K before it started slipping in the mountains trying to go up steep logging trails with the clutch fully engaged. The dealership said that new factory clutches were no longer available only rebuilds. There are a number of clutch kits I considered - I just happen to decide, based on the facts I gathered, that the dual friction clutch from Centerforce was the clutch of choice for me.
I say stick w/ stock anywhere you can as the oem part will always!! be a better part, just remember that any part can be abused. it would be a waste of cash and effort in my oppinion to go any other way. But hey! you asked. And you know you'll get a wide variety of oppinions on Mud. Use your own judgement. you know how your going to drive it!
