clutch problem?
Vancouver, BC, Canada.
Website
www.paool.com
My 78 Fj40 was running great all weekend, the clutch had no slipage or anything like that... But after dipping the front end in up to the hood in mud I lost all drive to the wheels. A close buddy suggested the clutch just was wet and should be left to dry out for a bit. That kind of helped and after some time the truck would move just barely on its own in 4lo. Anyways after getting it towed home I decided to log on and get some opinions from you guys as to what the problem might be. The clutch seems to be only engaging a very little bit because I can still move slightly, but revving the engine makes no difference in how fast It moves. I was thinking of dropping the tranny tommorrow to take a peek at the clutch, but wanted to know if anyone here might know why it would just give out like that... one second its perfectly fine, the next i have no drive at all. Also, the Clutch fluid looks pretty milky and dirty.. I'm sure thats pretty bad, but any ideas If its related to my current problem?
if you have a diafram clutch and the mud is watery when you push the clutch in it will fill with mud i take the cover off the tranny bottom hold the pedal down make sure clutch is disengaged and hose it out good have to rotate it to get it all when it dries it usally works fine have done this on the trail using air and wire to get mud out if you do this a lot you need to seal the bell housing and vent it the mud bilds up in the ring around the to bearing and stops clutch from working hope this helps hosed some out 4or so years ago and they still work
You probably stepped on the clutch when you were stuck and got mud and dirt in the friction surfaces.
Try washing it out first before you go to all the trouble. Take the inspection cover off, have someone hold the clutch down, start the engine and run your power washer between the flywheel, disk and presure plate.
Don't ever step on the clutch pedal in mud or water.
Im takin the inspection cover off in 20 minutes after the underside dries up a bit (washed it), then after I pressure wash the friction plate and area i'm gonna bleed the clutch lines and top up the fluid. I'll post back if there's any problems.
Whew.. thanks for the tip though, that coulda saved a lot of work.
Make sure that the tranny is in N if you get underneath to spray.
You're not out of the woods yet. If you ran it wet and slipping you might have ground down the friction surfaces. Washing it is worth a try though. If fyou can't get enough gap between the disk and the flywheel and pressure plate to get the water in, try lenghting the adjuster rod at the slave to put more pressure on the plate.
