Clutch Engagement
Inland Empire, Southern California
I replaced my 3speed to 4speed. The challenge that I have is that I have to push the clutch to the floor to engage. I adjusted the pedal and slave without much success. I noticed that the clutch release bearing is quite far from the diaphragm. So I put a washer between the clutch plate and the flywheel to bring the clutch plate closer to the bearing. Still not quite there so perhaps add another washer. I cannot imagine this is the correct method. The picture of the clutch plate was before I added the washers. Any guidance would help.
Thanks. Originally I had the plate to the flywheel and then later added a washer there to bring the plate closer to the bearing away from the flywheel.
As bryon said, Do not put washers between the pp and flywheel. This will most likely cause the the clutch to slip. The rounded nut on the adjustment rod needs to be on the other side of the clutch fork. Between the slave and fork. Then adjust.
Are you using the 4 speed clutch fork pivot?
Good eye
That's it. Right there. Easy fix.
Ok, how about the clutch fork pivot ball? Does that make sense?
