Using the clutch arm I was able to push it in, I'm not sure if I could push it by hand alone. I'll try in a fewCould you physically push it in by hand ? Was it really stiff or just some resistance?
I gave this a shot last night and can confirm it's not returning to the bottom of the bore. More like hanging out in the middle
Ok, I had it setup so the to bearing was just off of the clutch fingers at teat
Does the clutch arm pivot ball come into play at all? Mines adjustable and it looks like it's threaded as far out of the back of the bell as possible towards the trans
Nice sometimes you have to do it that way to make sure the piston is fully retracted. Tighten the push rod up as fsr as it will go and then back it off and set the gap. I would put a bigger return spring on it also maybe yours is to week, you want that return spring to pull that piston all the way back into its bore. Do you have a return spring up under the dash for the clutch pedal ?
