Climbing temps with AC on
South of Houston
Just went through the cooling system with all new components, usually runs 190-193 max. In the last week here in Houston it has been hotter than normal, when the ac is on running down the highway at 60-70 mph with no ac on temp rarely sees 193, turn on ac compressor and the temps climbs until I turn off the ac at 220, when I do turn the ac off the temps start dropping back to the low 190's. Th ac blows cold and appears to have no issues besides climbing temps, what gives here? Bad compressor or wrong freon pressure? Ideas???
You replace your fan clutch or modify it?
It is a blue hub clutch and no I never have messed with changing the oil. Today it was rock solid temps at 188-193 with no AC on, so I can only assume that the cooling system is doing a good job as the 193 was only at the toll booth when I stopped temporarily other than that it was 188-190. Maybe I do need to change the oil to a thicker viscosity! School me on the different oils to use please!
If you're referring to different fan clutch fluids, then LCP, Tools, LandTank & a couple others have got it down pat. Depending on which clutch you have will dictate how much & what viscosity to use. It's pretty easy to do regardless which one you have.
it is a little odd. i tend to agree with the new radiator. but it does not exactly match mine when i needed a new rad. my ac only added about 10 degree to temps when my rad was bad and it was running warm on hiway even without ac. but now with new eom rad ac only adds about 2-4 degrees.
i would think if your compressor was ba enough to put a LOT of lode on the motor so it was working that hard you would feel it in the way it drives. so that makes me think it is just the extra heat from the condenser that is pushing it over the edge. and that kind of does sound more like a coolant issue than ac.
PS if you do get A new rad, i would callo CDan, Sam or Beno and go OEM. the price is almost the same as aftermarket and you know 100% it is good to go.
also, look at it like this. if you coolant systm was good and the compressor bad putting a huge lode on the motor. it would be like pulling a heavy trailer. you should feel it in the way it drives. Also a good coolant system still wouldnt overheat with a trailer behind it. at least i dont think so. the fan clutxh is cheap and easy so start with that. but when you do it. make sure you install the fan shroud right and secure the lower edge in the clips. or you will be buying a new rad like me anyway :)
Have a look in front of the radiator itself (not the condenser). I have seen many Cruisers,Tundras and Sequoias plug up with fine materials and cause poor temperature control. Air flow is key for fan clutch operation. Before you modify anything make sure it clean. Its a high efficiently radiator with small cooling fins that clog up easily. Most of the time the best way to clean it is to remove it and use moderate pressure water to back flush the core fins. Finish with compressed air but not to close as the fins are fine and can bend easily. If you don't want to remove it, back flush with water and see if materials come out of the front of the core. The system is designed to operate in extreme conditions. Fan clutch oil mods do work but if not done perfectly can cause poor fuel mileage and excessive fan bracket bearing wear and lower belt life, Bill
Hey all, I do have a new radiator (brass 3 row OEM) a well as new thermostat, new hoses and new water pump. By new I mean I have replaced all these items in the last year to year and a half. The front of the radiator is clean and not obstructed by debris. The fan clutch (even though it is blue) is the one that was on the truck when I purchased it 3 years ago.
Does your fan clutch roar pretty good when it's hot? On startup? If so, then replace the radiator, they do go bad. And go aluminum. I can idle in triple digit weather and see maybe 190F for coolant temps.
He has a pretty new OEM radiator..
Let it be known LCP is not a fan clutch guy
Tool-r-us is your goto guy for peak performance
Do you have all the foam seal pieces in place around the radiator?
Robbie @powderpig was pretty insistent on those being there.
Also dont overlook the foam at the of the radiator - most overlooked cooling component
The last few posts on my on going thread (see sig) deals with removal of the mechanical fan, not your issue here but what the thread does is educate about the cooling system in general. I can confirm without any doubt the AC system dumps at least 5 degrees C into the engine radiator. The foam padding around the edges of the radiator is waaay more important than you realise.
Unless a new thermostat is tested outside the engine you cannot trust that it works once fitted.
regards
Dave
Tonight the newest data I have, outside air temp approx 85, 63% hum. running 60mph no a/c it maintains 186-188, idling moves up to 190. Running a/c the last 10 miles at 60 and slower and it gets to 193 right at the house. It seems to me that the cooling system is working pretty much the way it should, the new OEM rad came with all new foam, good fan shroud. Maybe the a/c does dump that much heat into the engine cooling system but we are talking a difference of 193 slowly climbing up to 218 before I wimped out and shut he compressor off.
So many variable here. You say you wimped out at 218, I would have left it, there is a protection circuit that will shut off your AC. I would check the temp yours is supposed to cut out. Also, what are you using to check temps?
regards
Dave
If the fan doesn't fix the problem. find a good a/c shop, with real temp sensors for the input and output on the condenser not a infrared it wont read right. Sounds like its either overcharged or you have some moisture in the system. Both will cause higher head pressure and a warmer than normal condenser. You also didn't state weather this is a 134a system, converted 134a or r12. Converted 134a will put off alot of heat also.. condenser in r12 trucks was smaller as r12 is a more efficient refrigerant. Good luck... went thru something similar on a cummins swap. It was a pain..
