Climate Control
Hey all,
I'm about to put a new interior into my 94 landcruiser and was interested to know if anyone had put in an upgraded climate control from a more modern vehicle? I'm having a custom fibreglass dash built and figured I might as well upgrade everything I can while I'm at it. any suggestions or recommendations would be appreciated.
Cheers.
Not necessarily an upgraded unit but the LX-450s have climate control of sorts.
In the sense that instead of setting fan and your balance of warm/cold air and it running non stop it has a thermostat and temps on the sliding switch and it will control the fan cutting on and off to maintain the temp you select.
May not be exactly what your looking for as it sounds your going all in on the interior redo.
And for others 95 and newer LC's (maybe the older too but cant verify) if you pull the a/c vent selector unit out of the dash there is a switch on the back labled A and M . On LC's it comes stock in the M (manual) position but switching it to A (automatic) converts it to the LX style climate control.
Free is always good. :) Hope it helps.
Awesome, Thanks for the reply, one of the major reasons I want to do this though is also the asthetics, I'm aiming towards a 94 cruiser that looks brand new and modern.....a lot of work but should be fun.
For closest to plug and play, JFZ80 has the best solution. Something to be aware of is the LX450 does have some extra wiring and computers to control all that. So upgrading might be difficult (and expensive).
What may be a better option in the long run is to find a climate control system that's designed for retrofits. You'd be ripping just about the entire system out and running it from scratch.
Want to detail the goals and plan?
I was under the impression that switching from "A" to "M", did not actually do the trick. Weren't there sensors and other electronics that are not installed in those vehicles?
i know that the auto climate controlled cars Definitly had a little temp sensor located under the car somewhere that took an outside temprature reading along with an interior sensor and these are used by the computer to adjust the temprature. I believe the actual heating unit is similar between 96-97as to having the the control module being similar however the extra components are needed to control the auto climate function. Would be cool thong if it was just a switch to go from manual to automatic!
The 40th Anniversarys also have auto-climate control as well. Not sure if it's the same unit in the LXs...
Ben,
You very well may be right. I should have used more caution/an asterisk for repeating what I had read several times here on mud over the years. I have a unit here in front of me and there is no extra sensors mounted to the unit (so it would have to be internal but that is blocked from free access to cabin air) or what not but I the truck is not here to inspect what may be hardmounted to the dash internals. there is a lil vent louver about 1/2'' by 1/2'' that could allow internal air temps to reach a sensor but if it exists its not mounted to the dash plate but rather would have to be mounted to the frame of the dash.
Ben,
There is an external temp sensor on the front of the vehicle, passenger side, just behind the bumper. (Assuming it has the fully auto controls.)
If that is missing, the automatic controls should still work, just not as effectively...
Just a FYI:
I just finished looking into this option as I had both a standard 1997 LC and a LC40th at my disposal. Other than the external temp sensor in the front bumper and the internal sensor the plugs into the climate control unit, THERE ARE ~14 EXTRA WIRES IN THE CLIMATE CONTROL HARNESS...
I stopped when I saw this. Either get a LC40th or a LX450.
