Yes, rev the engine to about 3000 rpm with the hand throttle, then remove the air cleaner and pour several hundred pounds of beach sand through the carb slowly. This will also port and polish the intake and exhaust system.
Some will offer things that can be poured in and maybe work a bit of loose stuff out but I think to get stubborn deposits off you will need to pull the head. It is not a tough job.
^ The traditional sand procedure will also GAURANTEE that your ride will never leave you stranded far away from home ever again...
If you dont want to remove the head, and if it's running fine I would not suggest it, the best you can hope for is to spray them with cleaner when you have the manifolds off.
i think i'm gona have to do a valve job. It runs okay cold with the vac sitting on 16, shudders a bit during acceleration, then once warm engine is shut off and re started idle vac constantly fluctuates between 15 and 18. Car runs smooth at 80+km/hr but acceleration is rough. Carb was re-built two weeks ago, but hasn’t improved problem. Timing, sparks, dizzy cap and rotor, leads etc all done recently.
Check the valve clearance to see if any are tight and adjust them if necessary. Do a compression test. If the compression is OK, maybe the carby job was botched.
I was complaining to my parts guy at Desert Toyota about the build-up inside my tail pipe and he recommended a product that he said was proven to clean the upper end of an engine (gas or diesel). I'm pretty skeptical about additives but he was very convincing. As he has worked hard to take care of my parts needs for 20 years, I decide to try a can of what they had displayed on the counter. It is made by BG Products and is called 44K. It cleaned my fuel system in just one tank to the point there were no black deposits on the inside of my exhaust pipe. I was so impressed that I purchased their system for diesels and when I went through emission testing the particulate percentage dropped from 7% the previous year to 0% last year and this year. I’ve got to hand it to this company because their products perform as advertised.
"BG 44K fuel injector cleaner, rapidly and thoroughly removes engine deposits on intake ports, piston crowns, cylinder heads and intake valves. It restores flow and spray pattern in fuel injectors and cleans the entire fuel system. BG 44K Power Enhancer improves fuel economy and reduces exhaust emissions."
Cheers for the feed back, have checked the valve clearances last weekend, several where tight and have been re-adjusted but little improvement... did timing at same time and got some improvemnt. Have noticed engine allways sounds like the valve clearance is out, but have never found the cause.
Honestly dont think the carb is the problem, but i suspect everything till the cause is found!!!
Yes i think a compression test is the next logical thing to do, though my mechanic thinks it will be good when cold, and when the engine heats up and exhibits the problem, i wont get the compression test done before its cooled down and gone back to normal... he thinks the vacuum test is the best indicator at this stage, and as i mentiond its fluctuating markedly at hot idle, but smooth as when cool, suggesting possibly a sticky valve?
hmm no, but i reckon i would once it was hot...
has allways sounded a bit strange in the valve department, like a clack in amoungs the clicks...!
Have been running flashlube, but i think its not up to the job... and the problem is none of the brands you guys have mention exist over here... would Toluene do the job if i sprayed it through the carb whilst cars running?
My mechanic suggested redex or penetrine (like wd40 spay oil) through the carby, but havent had any luck.
A valve sticking only whilst warm is peculiar. I would think it would tend to stick while cold.
How about Marvel Mystery oil? Some old timers swear by it and it has been around for about 70 years. It is supposed to be like the ginseng of motors: a generally positive influence. You can put a little in the petrol tank for an upper cylinder lube, a little in the crank case and a little under the arm pits. I have no personal experience with it.
hmm, cant hurt to try... I think its about time for the head to come off though.
Will be doing 400km over the weekend so i'll see if i can find some or a local equivalent such as Moreys upper cylinder lube/cleaner which sounds good even though it comes from New Zealand
Is it any good for BO? i'll test drive it on my son!
