Chrome Rims Throwing Weights
Sandy Eggo
Website
www.markkuz.com
So over the last year I have been dealing with the wobbles here and there and taking care of it every tire rotation. After a few times of this I was realizing that the day after getting it serviced I would hear a loud whap in the wheel wells and wonder what I hit in the road. It finally donned on me that I was throwing weights. So I finally went to a new shop a fellow mud member runs and he explained that it was because the chrome makes the wheels a little thicker and the wights don't clamp on quite right. He didn't recommend the glue on weights also because of the chrome but he only carried the two options. So I guess I am asking two questions are you other chrome guys having this problem and what other weight choices are there? I am running 285/75/16 Cooper Discoverer STT's.
I have the external weights on my 80, but the rims are not chrome and all is well. However, my CTS just so happens to have aftermarket chrome rims and those weights are on the inside of the rim. Its not seen from teh outside, they are just stuck on and none of those came off. In fact its a PITA to remove them.
I think those stick on weights are a good way to go. They are concealed and won't be flying off.
I have normal LX450 rims (not chrome) and they still throw the weights that get clamped to the rim edge.
When I watched the guy install them, it doesn't look like they really clamp on very hard...so I'm not too surprised. I'm just going to buy a wheel balancer off ebay, and a bunch of tape-a-weights for the inner part of the rim and do it myself.
I've had no issues wih the stick on weights, have not had any flying off on my aftermarket wheels, PITA to remove though, maybe brake clean will loosen them up? :cool:
That's right, you need the right weight. There should be no such thing as throwing weights because the weights have steel clamps that are a bit flexible like a spring. So when they are knocked on, they should apply constant clamping pressure and not fall off. Wrong type is used in your case probably.
The sticker weights are even better as the centrifugal force pushes them against the rim. There is no way they could fall off. Just make sure you go to the right guy.
anyone here ever heard of ceramic beads?. apperantly big rigs use them. you just put a certain ammout inside the tire depending on the size of the tire/rim, and way u go.
yup, the dynabead or equal products balance from the inside. take a moment to distribute and then smooths out. if you wheel and air down id get the beads as the equal can clog valve stems; or if youre cool enough hit the wally world for some bb's:hillbilly:
http://www.innovativebalancing.com/
I know that chrome is rejected like a bad heart transplant on a 40. Maybe there's enough 40 in an 80 to cause problems like that?
Ok, doesn't help. Make sure your shop is using the correct weight for the rim (there's a book).
I got this info from a MUD member who runs a Toyota only shop and rolls in a LC just like us. And the weights are not spring loaded but because of the thickness it spreads them open just enough to not allow them to clamp on flat at the edge. He is looking for other options in weights and I am trying to do the same with no luck so I thought I would ask you guys.
:ban:Its because chrome belongs on Heeps not Land Cruisers.:doh:
Bluetribal said:
Well I may have to move away from chrome? I was going to chrome my spare to make my tire rotations less hassle but now I may have to sand blast all (4) chromies if I can't find weights that work.
DO IT!
Either that or have the Hanna bumper chromed to match. :hillbilly:
Mine are chromes and they have had stick on weights for years - none thrown.
Bluetribal said:
But as soon as I un-chrome them they will lose the force field and I will scratch them up like you do. :flipoff2:
Hmmm. Good point.
Bluetribal said:
Hmmm, I guess I will just have to try the stick-on weights.
I use stick on weights. I was ripping off the standard weights every time I wheeled.
