Christmas tree lights...
Utah
...or a lack thereof...
AFAIK, the "Christmas tree lights" are supposed to come on with the key in the "On" position, engine NOT running. Right? Well, as far as I can remember, my 80 has never done that, save one time. Also, when my aftermarket alternator died last year, there was no warning light. (replaced with OEM)
I know the bulbs are good, because at one time a few months ago, all three lights (Charge, A/T P, Brake) lit up before I turned the key to "Start". Like they are supposed to.
I've tested the charge lamp relay according to the FSM, it checks out fine, and the fuse is good (tested both with multimeter).
I've also done a fair amount of searching and checking the FAQ, but I haven't really come up with anything...
And, yes, I realize that this is probably really stupid. Either you're all gonna think, "Why does this guy want the lights ON?", or someone is gonna post in the next 5 minutes with a thread on this EXACT issue. Who knows? :rolleyes:
Thanks in advance,
-Lane
Yeah, the truck starts. Before I start it, I get the CEL, Door, and Seatbelt lights, but thats it.
I'm trying to figure out why nothing else comes on before I start it...
Pretty sure the owner's manual should state exactly which dash lights should be illuminated with the engine off, key in on position.
Funny story, actually... I lost my manual. :doh:
Sounds like the only light missing is the "charge" lamp. Did you reseat the charge lamp relay in the fusebox?
A couple times, actually. I tested it twice, to make sure that it wasn't bad.
You know, the more I think about this, the more I start to think that the charge lamp bulb has gone out...
:doh:
Off to tear the dash apart.
Just got back in... All the bulbs are good, all the fuses are good. I made sure to check those two fuses twice.
:confused:
That's odd, mine turns on when I turn the key to "Acc" :confused:
